Old 04-25-2013, 12:53 PM   #21
RonC
RonC's Avatar
Default Re: Pix added: Best way to clean up valve seats & a couple other questions
The engine looks like it has high mileage. If you don't want to spend the money on a rebuild you could replace it with a good running used engine. Maybe you could buy a good running chassis and swap out the engines??
RonC is offline   Reply With Quote
Old 04-25-2013, 01:01 PM   #22
Kohnke Rebabbitting
As Ford 3 said pull the engine. Your 4 & 3 are pumping oil, and 3 is the worst.
I think the cylinders will have to be bored, as fitting a round ring to a egg shaped hole is not possible.
Put in modern S.Steel Valves, with over size stems, Glue in the old lifters, and bore for the New S.S. valves.
Check the whole engine, and then all you have to do is drive it the rest of your life.
Kohnke Rebabbitting is offline   Reply With Quote
Old 04-25-2013, 04:35 PM   #23
Tom Wesenberg
Tom Wesenberg's Avatar
Your engine sounds just like my teporary well used engine. I have 50 lbs. on each cylinder, good power, but a ticking near number 3 cylinder. I think it's piston slap, but I'm just going to keep driving it until it really needs to be worked on.
I wouldn't install valve seats, unless it really needed them. I would measure the cylinders for wear, to check for taper and egg shaped. Let those measurements determine how much work needs to be done.
Old 04-25-2013, 04:45 PM   #24
700rpm
700rpm's Avatar
So far all your comments have convinced me to pull the engine and make some serious inspections and measurements. So that's my next step. If anyone has some more observations, I'm still open. But having the engine out will help me with the inspection process. When I get the engine out and apart I think I'll start another thread since this one has strayed from my original issue of valve seats.
Ray Horton, Portland, OR
Old 04-25-2013, 06:37 PM   #25
Patrick L.
Patrick L.'s Avatar
700, were you having any issues with the engine except for a bit of valve lash noise ? You said you had good compression. Was it using much oil ? If it was running good and not using much oil, why mess too much with it ? Thats just my opinion though. I don't see a problem with just fixing the valve lash problem and run it for years. But, if the engine comes out, then I'd it have completely re-done, its only time and money.
Old 04-26-2013, 01:11 AM   #26
700rpm
700rpm's Avatar
Patrick, the annoying issue was a ticking noise, as explained above. There was a pretty good oil leak from the rear main, about a 3-4" puddle after a long drive. Short drives sometimes didn't produce any leak at all, or very slight. It didn't seem to burn much oil. because of the leak and the ticking, I had planned to take the engine out this spring or summer and have a good look at it, since I don't have any history on it. The degree to which I will rebuild it will really depend now on what I find once I pull it.
Thanks for your help and your interest. All the comments have been informative and helpful in pushing me along.
Old 04-26-2013, 06:50 AM   #27
Patrick L.
Patrick L.'s Avatar
OK, I understand. Once its done correctly, there should be no more worries.
Old 04-26-2013, 07:23 AM   #28
Special Coupe Frank
Special Coupe Frank's Avatar
"The degree to which I will rebuild it will really depend now on what I find once I pull it."
Sounds like a reasonable approach !
Special Coupe Frank is offline   Reply With Quote
