04-11-2011, 09:29 PM | #21 |
Re: 53 Mercury camshaft
ford
04-12-2011, 04:16 AM | #22 |
Camshafts are an interesting topic. I have a cam that has 21A stamped in the end, but 5T cast on the shaft....and another that has 5T stamped on the end, and 21A cast on the shaft....what gives??
05-22-2011, 09:57 PM | #23 |
well ive got a standard everything what i thought was a 53merc engine with a 8cm cam in it
04-26-2016, 08:31 AM | #24 |
It has been stated that the 1cm cam has 236* advertised duration, curious what it is a .050 lift?
04-26-2016, 01:50 PM | #25 |
04-26-2016, 05:51 PM | #26 |
04-26-2016, 07:13 PM | #27 |
It would be easier if I had the cam in hand. Thanks flatjack for posting your info.
04-27-2016, 12:19 PM | #28 | |
Just out of interest, what do you not like about the cam in there now? And do you actually know for certain it's got a 3/4 "of somesort" I ask as if you don't know for certain what cam is in it, you could be swapping in the same cam! For instance, when you buy a car and chap says "it's got a 3/4 cam" kinda goes with "it ran great when I parked it", Were you just told that's what it had? I'm not doubting your knowledge, I just don't want you doing unnecessary parts swapping. Martin. |
04-27-2016, 05:12 PM | #29 |
The Merc cam has around .330 lift whereas the Ford is .300. The cam will have either 8CM or 1CM cast somewhere along the length of the cam.
04-28-2016, 11:58 AM | #30 |
I too have a cam that is marked EA A although it is marked slightly different than the one pictured in this quote. Is this the same as an EAB cam or what do I have???
The more I learn about new automobiles, the more I value my old ones. |
05-03-2016, 09:31 PM | #31 |
I've got a cam marked c23,came out of an eab motor I stripped in az, anyone have any info?
