04-14-2012, 05:14 PM | #21 |
Re: Model A motor mounts
Purdy Swoft's picture of the AA looks just like my mounts. But I do not see the rubber in his either.
04-14-2012, 07:18 PM | #22 | |
BTW, whats the shouting about?? |
04-14-2012, 07:31 PM | #23 |
You won't see the rubbers in a picture like that.The L shaped pads go inside the frame rail between the mount and the rail,and the flat one goes between the outside plate and the outside of the frame rail.We know now though that you have original type mounts.You may still have rubber in there,but squashed so tight you can't see it.There is no rubber between the mount and the flywheel housing.When you take it apart check for cracks,if the rubbers are beat out and the mounts have been bouncing on the frame they may be cracked.They weld like butter,so it is not a big problem.Also,do one at a time.That way you can do it with a floor jack.
04-14-2012, 07:43 PM | #24 | |
04-14-2012, 07:55 PM | #25 |
Registered User
joe
the first picture shows the motor mount with the rubber that fits inside the frame,darn i took it upside down,the flange on the rubber is on the bottom the second picture shows the outside of the frame with another rubber between the frame and plate i agree with Pat,I have three very smooth running engines they dont compare to the super balanced engines of today,but by no means do they shake the car excessively tom |
04-14-2012, 11:48 PM | #26 | |
Not "shouting," just hard of "seeing!" Thought it would help some others who may not see like an Eagle. Others have favorite fonts, so why do I get picked on? (Sniff!) How's this? I've ridden & driven many Model A's, they all have some inherent vibrations, low milers are almost always better than an old loose ratteley trap! I have a friend with a Cabroilet, and he attributes it's better than average quietness to the large amount of wood in it that helps absorb some of the inherent sounds. I was only sharing ways to make them a little smoother and quieter. Sold my '30 coupe with all the changes and will soon be driving my "bone stock" Avatar, '29 coupe as it is. The only changes are 16" wheels, 6 blade fan, and coolant overflow tank. Last 2 mods are 'cause it gets dang hot in Fresno! Am I out of trouble yet? Did I use appropriate "smilies" & "un-smilies?" TROUBLE is my middle name! Bill Trouble W.
04-15-2012, 12:23 PM | #27 |
The mounts can be removed and replaced with new rubber without removing anything but the mounts Use a hydraulic jack to spread the frame for some clearance if needed. do one side at a time with the engine blocked up from the floor. It is a relatively quick and easy job.
04-15-2012, 02:39 PM | #28 |
First of all I need to hand out some compliments. You senior guys on this forum do so much to help preserve American History in relation to the Model A. Those of us who just do not know a lot could not help keep our cars or trucks going without this help. I know I am always trying to get some free info out of yall(I'm from Texis) but it really is true. This thread has been very helpful to me because I have come to the conclusion I have such a bad vibration it is not the motor mounts. I actually see the rubber now. I am thinking it is my u joint. How do I take a look at that to see its condition.
04-15-2012, 04:04 PM | #29 | |
04-15-2012, 06:54 PM | #30 | |
Have you had the wheels checked for being bent or out of balance? Remember the red dot on the tire goes out side and lines up with the valve stem. I am sure there are some experts that have a way of telling if the u-joints are bad. I guess you only have the vibration when you are going down the highway. If the vibration occurs when in neutral and and not moving it probably is not the u-joints. The rear end is easier to pull than the engine. Just make sure you have it blocked up good. The u bolts on the spring, brake rods and the cover behind the transmission and the speed-o-meter cable will have to be removed. The shock arms will have to be disconnected. The spring should be clamped with c-clamps in case the center bolt decides to let go at any time. The tire and wheels will have to be removed to clear the fenders. The biggest thing is safety and good blocking under the frame. A good day with a few coffee breaks and lunch you should have it out in a few hours. Pulling the engine seems to take longer because of the light bar, radiator, fuel line, carburetor linkage and wiring connections. The exhaust pipe will have to be disconnected to pull the engine too.
IF IT CAN NOT BE FIXED WITH BLASTING WIRE, JB WELD OR DUCT TAPE ---IT CAN NOT BE FIXED Do not get me started on the stupidity of ethanol. I think one of the monitors is from Iowa and he will delete the thread. Last edited by sturgis 39; 04-15-2012 at 07:06 PM. Reason: added exhaust pipe |
04-16-2012, 05:53 AM | #31 | |
2. Tires manufactured today either don't have balance marks or the dots do not mean anything to anyone except the manufacturer. The rest is absolutely correct since the engine/transmission is difficult to remove as an assembly.
