Old 05-23-2024, 08:08 AM   #21
Bored&Stroked
Bored&Stroked's Avatar
Default Re: One Head stud too short each bank follow-up
It will be a fine engine - you know what you're doing!
Given the type of studs you're using, definitely put it through a couple heat cycles and retorque the heads a couple times.
Also, you might consider running a bottle of Moroso Ceramic Seal through it on the test stand - can ensure that no studs leak and doesn't hurt anything. A good thing to ensure the customer doesn't have any drama.
Old 05-23-2024, 08:23 AM   #22
rockfla
rockfla's Avatar
Thanks once again for the Ceramic Seal tip, I will do that!!! I "leak-Loc'd" all the studs on installation BUT I like "added" protection!!!
Old 05-23-2024, 08:32 AM   #23
Tim Ayers
Nice work, Robert.
Old 05-23-2024, 08:40 AM   #24
rockfla
rockfla's Avatar
Originally Posted by Tim Ayers View Post
Nice work, Robert.
Thank you very much Tim. Hope all is well with you my friend??? Take care
Old 05-23-2024, 08:43 AM   #25
Tim Ayers
All is well. Hope the same with you. Learned something new. Never seen that Lube Lock product before. I like how it comes in a liquid. Paste products can be quite a mess. Have you used it before?
Old 05-23-2024, 11:24 AM   #26
rockfla
rockfla's Avatar
My good friend here in town who does "flathead" builds and has been doing them for years turned me on to it. This, and my 4 cyl for my Proto-type WWII Jeep are the first two builds I have used it SO.......Ben learned of it years ago, his brother is a good customer of mine and more recently has focused his business, strictly on Military bases here in the southeast. Ben works for him "occasionally" and they were rebuilding some large heavy duty A/C compressors on a Navel Base and the compressor mfg spec'd this for the compressor studs. He was helping on that job and saw what the compressor did, how hot they ran and so forth and figured, Heck, that would work on Flathead head studs....SO he has been using it for several years and swears by it!!!!! I run a small bead of it around the first couple of threads and one bead running up the thread length just about 2/3 threads shy of the top, it forms a nice seal and bead at the surface and you can see it spread across the threads as you thread the stud in. Good stuff and comes highly recommended. IF you like I can snag you a tube from the A/C parts supply house across the street from me, that's where I get it....I have also turned a couple of "Jeep" buddies onto it (Amazon) and they are NOW using it!!!!
Old 05-23-2024, 11:28 AM   #27
petehoovie
petehoovie's Avatar
The only thing nice about being imperfect is the joy it brings to others....
"Silver rings, your butt! Them's washers!"
"We shot our way out of that town for a dollar's worth of steel holes!" - from 'The Wild Bunch' - 1969
https://www.youtube.com/watch?v=7NReUd2_0u0
Old 05-23-2024, 11:30 AM   #28
rockfla
rockfla's Avatar
Thank you Pete.
Old 05-23-2024, 11:35 AM   #29
rockfla
rockfla's Avatar
LEAK LOCK
https://www.blueridgecompany.com/rad...aling-compound
Old 05-23-2024, 12:15 PM   #30
petehoovie
petehoovie's Avatar
Leak Lock Joint Sealing Compound
Leak Lock is a state-of-the-art, resin-based, high strength, brushable paste pipe joint sealant consisting of chemically resistant film formers, plasticers, reinforcing fillers and solvents.
  • Remains permanently flexible, adheres to internal surfaces and fills voids.
  • Suitable for all metal or plastic materials.
  • Ideal for joining dissimilar metals and materials.
  • Prevents loosening of plugs and fittings even in applications subject to extreme vibration.
  • Effective in temperatures from -200F (-93C) to 400F (204C).
  • Withstands full vacuums and pressures to 10,000 PSI.
  • Perfect for threaded joints, flanged joints, gasket surfaces and all mating surfaces where a fluid-tight seal is required.
  • Seals a broad range of chemicals, petroleum products, natural and manufactured gases, steam, water, air, etc. No other sealant offers the application range of Leak Lock.
Old 05-24-2024, 11:18 AM   #31
Als48
I'm pleasantly surprised to hear the name, Leak Lock brought to our attention. I remember testing that product for use in the Chemical plant where I worked for 34 years. Our lab tested Leak Lock for use in elevated temperatures and various types of systems, such as lube oil, freon coolants and antifreeze agents used in the cooling water systems. If I remember correctly, it has a fluorocarbon filler (Teflon) and was found to be very good in most of our plant systems for sealing threaded and flanged joints. A very good product, in my opinion. Of course I've been retired for over 20 years, and haven't heard that name since retirement. Probably a DuPont product or derivation.
Al Hook
Als48 is offline   Reply With Quote
Old 05-24-2024, 02:17 PM   #32
rockfla
rockfla's Avatar
Al Hook
Al
That is a great testimony and endorsement, thank you for sharing......B&S Tim and all other following (From a parallel (of sorts) post here on the barn)
Make sure you clean the threads really good, I used a thread chaser along with carb/brake cleaner with a shop towel. THEN when time came to actually install the studs, I took another shop rag and the carb cleaner with the straw and partially stuck the shop rag into each whole and cleaned with the carb cleaner again to make sure I had a good clean surface. Just an FYI and best performance of the leak lock
