#21 |
I believe the front engine mounting bracket was originally Ford Red, painted along with the rest of the assembled engine. It may be listed somewhere in these linked pages...
https://www.ctci.org/wp-content/uplo...enticity-1.pdf . |
#22 | |
![]() Quote:
I have come across an MPC ILL that shows the slinger on a 55/ . I think what happened (the 54 239 did not have a slinger) is that at some point in the 55 assembly year, engineering discovered it needed a slinger. That slinger does have a 1956 model year PN PREFIX (and again, this might be a super-seceding PN). It may be that there was a SERVICE BULLETIN describing all of this. Without a full collection of service bulletins of the period, subjects such as this is all conjecture. But regardless, it needs a slinger (IMO). If the engine had the early cam drive, all of it should be retained (IMO). When FORD re-designed the cam drive mid-1956 production, it also deleted the rocker arm drip shields which in turn changed the valve-train geometry and different length push-rods were used along with rockers. All of this has to be taken into consideration (again IMO) when modifying the valve-train. |
#23 |
Again I could not find the slinger listed in my 1955 Ford chassis parts catalog Form 7516 November 1954.This was succeeded by same Form # 7516 but was dated Sept 1955 and I don't have it but if someone does it would be interesting if it was now shown as a 1955 Ford part. My 292 engine in my January 1955 Thunderbird did not have a slinger but I was told they were a common part to missplace and leave out. I have placed one back on in anycase.
"Never complain,never explain"... Henry Ford II |
#24 | |
![]() Quote:
#25 |
Yes my post was a reply to you.I understood everything you said except for what an MPC Ill is.
#26 |
#27 | |
![]() Quote:
![]() Another KULTULZ 'FAILURE TO COMMUNICATE' EPISODE. MPC - MASTER PARTS CATALOG - (Contains CHASSIS and BODY CATALOG - TEXT AND ILLUSTRATIONS) ILL - ILLUSTRATION (or diagram) Your catalog is correct (early edition). I found two updated ILL's (SEP 1959 and APR 1964. I have only those two editions. The 59 edition shows the ILL (P-1865 / 9-60) and describing text as 'TYPICAL CRANKSHAFT, FLYWHEEL AND RELATED PARTS'. The 64 edition shows the same ILL (P-1865 / 1-64) and describing text reads '1955/ CRANKSHAFT ... Now both text sections show the slinger with a 1956 PREFIX PN. So you can see how cataloging can vary over the years. BTW, each year MPC was printed in calendar quarters and included any updating/corrections. So the catalog you have is correct. It (slinger) must have been added sometime during 1955 production. |
