Old 10-23-2022, 12:56 PM   #21
old31
Default Re: Wife wants Turn Signals
Has anyone hooked up a headlight as a signal light with just one bulb?
Old 10-23-2022, 01:04 PM   #22
BillCNC
BillCNC's Avatar
The last time I had a headlight flashing while driving got me a ticket, but I wasn't driving the "A". I'm not sure the law would allow a main headlight to be anything but on or off.
Maybe using the High as the flashing one and the low as the stay on one.
Regards
Bill
BillCNC is offline   Reply With Quote
Old 10-23-2022, 02:58 PM   #23
Y-Blockhead
Y-Blockhead's Avatar
Regards
Bill
If I saw that coming toward me I would say "What the ?? is wrong with THAT guy's headlights...". Not sure it would register to me a turn signals.
One of the reasons I use amber bulbs (1156A).
Old 10-23-2022, 10:13 PM   #24
dansluck
Send a message via AIM to dansluck Send a message via Yahoo to dansluck
I have 2 Model A s that have Logo Lites installed. Easy to install, 6 or 12 volts, Led lights.
Dan
dansluck is offline   Reply With Quote
Old 10-24-2022, 07:31 AM   #25
Grumps
Thanks for all the information. I got an idea of what I need and what to do now and will do a follow up later.
Grumps is offline   Reply With Quote
Old 11-21-2022, 04:07 PM   #26
Technite73
Tom, I have this kit in my newly acquird 1930 Cabriolet.
I did not get any paperwork or iformation on the kit.
Do you have the instructions or a schematic?
Thanks,
Ron Russo
Technite73 is offline   Reply With Quote
Old 11-21-2022, 04:30 PM   #27
Gene F
Gene F's Avatar
May I ask...at the national events, I always thought that safety items are not a deduction of pints for a judged car. I am thinking, fuises, turn signal system, cast iron drums, the outdoor mirrors, etc. ???
Gene F is offline   Reply With Quote
Old 11-21-2022, 04:43 PM   #28
Synchro909
Synchro909's Avatar
Here, turn signals are considered a safety item and suffer no loss of points if the car is judged.
There are many, many different lights used but here, the turn signals are amber front and back. Using the brake light as a turn signal has been banned since the mid fifties. Some of the most popular lights are from motor cycles except Harley Davidson. IMO, they are too small.
I'm part of the only ever generation with an analogue childhood and a digital adulthood.
Old 11-21-2022, 06:15 PM   #29
Gene F
Gene F's Avatar
My car was built March 1928. It has a single tail light. I did add the window mounted aux breakelight. I had a LED buds tail light, but I could not keep it working. I took it out, and went back to a incandescent bulb.
I see cars fitted with turn signals that fir detween the horizontals of the bumpers, and they look fairly slick. I think Macs and Snyders both sell them.
Old 11-22-2022, 10:21 AM   #30
Bob Bidonde
Bob Bidonde's Avatar
My Victoria has Bratton's 20401 Main Harness with integral turn signals. The system uses the cowl lights and two LED tail lights for signal lights. Since 2016, this turn signal system has worked well, i.e., no parts failures and excellent in modern traffic. The 20401 system does not self-cancel the signals after a turn, but I positioned the Signal Stat below the spark advance quadrant. As the steering wheel recovers out of a turn, my hand on the steering wheel naturally passes the long lever of the sign stat making it very easy to cancel the lights.
I am going to replace the add-on turn signal system in my Coupe with Bratton's 20401.
Bob Bidonde
Old 11-22-2022, 01:12 PM   #31
Bud
Bud's Avatar
Years ago I bought a turn signal switch that had a rubber roller in the top. The roller is supposed to be mounted against the steering wheel. The purpose of the roller was to cancel the turn signal. I never mounted it or tested it. Has anyone ever used a turn signal like this? Did it work correctly?
Bud is offline   Reply With Quote
Old 11-22-2022, 03:40 PM   #32
CarlG
CarlG's Avatar
I have the same thing that Bob has except that I bought mine from Sacramento Vintage Ford. 12 years and 25k miles and still going strong.
Alaskan A's
Model A Ford Club of America
Model A Restorers Club
Mullins Owner's Club
Old 11-22-2022, 05:32 PM   #33
Dick Carne
Dick Carne's Avatar
Thought I might weigh in on this as well. My friend, Jim Cannon, installed one of the Turnswitch / Electro-Tech units on our Cabriolet - it works great. Rather than a turn switch lever on the steering column, we elected instead to install a toggle switch under the dash rail just above the instrument panel - it is effectively out of sight and as was noted above, you would have to lean down to see it. The Electro-Tech unit is also self-cancelling, and has a low but audible beep to it as well. If your car has cowl lights, I might suggest that you use those instead of the headlights. In my opinion, folks are not inclined to consider that a turn signal would typically be found in the headlight proper. By the same token, those with additional lights added to the bumper or the lower part of the front of the car, may also find that these may not be as easily seen as something higher on the car's profile would be. In that regard, Snyder's (and perhaps others) carry a cowl light turn signal conversion kit for both 28-29 and 30-31 vehicles. We have three other restored Model A's, and as time and resources permit, it is my plan to add this feature to those cars as well. Good luck whatever route you decide to take.
Dick Carne is offline   Reply With Quote
