01-24-2011, 11:33 PM | #21 |
Re: lowering a 41 ford
A lot of advice here but lowering the 41 is a whole lot different than 42-48. The front end is totally different with the 40/41 sway bar and shock setup. The rear has a different spring setup which was changed in 42. I've had them low in the front, taildragger and stock. I stopped trying to outguess the Ford engineers long ago
01-25-2011, 01:43 AM | #22 |
can you tell me what problems you have with longer shackles, I was thinking
about putting some on my 46 coupe, they sell them at SO-CAL. they are about 2 inches longer than stock, what should I expect, will it change the ride or handling |
01-25-2011, 09:50 AM | #23 |
01-25-2011, 09:53 AM | #24 | |
Except mabye hitting the bumpstops earlier :-) And the good thing with longer shackels ia that you can remove them quit easy if you dont like them :-) |
