#21 | |
![]() Quote:
#22 |
I always set mine by "total" advance , not idle advance . I got my light at a swap meet . old but works well .
V4f |
#23 | |
![]() Quote:
Timing lights, per se, are basically all alike, that is, they light up the timing marks/pointer that YOU made, that are on the crank pulley. I have an antique light , which is the most basic and easy to hook up , but doesn't have the BRIGHT light that more modern lights have. Note: The oldest light has chips out of it due to fan and getting too close because light is weak ![]() Warning: Using almost any timing light involves hooking up wires/clips/etc...watch that these do not lay onto the exhaust headers/manifold..as they burn. |
#24 |
We (very much like Zipper) use a fork lift core to make a nice "Mallory" single point unit for the Model A engine . After doing a hundred plus of these (almost out of cores) the only issue I have had is some engine want more advance. We ship our Mallorys with 30 degrees at 2000-2500 rpm.
There are a lot of different combos with the Model A engines for sure. Every Zipper i have tested has been right on!!!! http://www.bubbasignition.com/4-bangers.html |
#25 |
The reason I ask is that I have a CP7529 Digital light from Actron.
I don't want to have to buy another light and would like to see if someone knows how to make this one work with a FSI Zipper and 6 volt positive. https://www.summitracing.com/parts/a...yABEgLGG_D_BwE |
#26 |
#27 | |
![]() Quote:
You probably could use it using a separate source of 12V DC to power the light.
#28 | |
![]() Quote:
that's how i do it all the time works fine Tinkirk/Terry |
#29 |
x2 - I've done it that way many times (I use a 12v JumperPack).
If at first you don't succeed, skydiving isn't for you! You don't need a parachute to skydive, you only need a parachute to skydive twice. |
#30 |
petew, do you remember what size springs you installed to alter the advance curve? The FS zipper I believe comes with 16 or 20 thous.but not sure.
#31 |
After many problems, I gave up on my FS, electronic ignition, and went back to the stock system. My Model A now runs better than ever. Plus I now have control of my spark on hills. Henry knew best.
#32 |
I have run an FS auto advance distributor for several tens of thousands of miles. At first, I didn't like the way it caused pinging under heavy load, even at touring speeds. I retarded it little by little till the pinging could not be induced. I've driven the wheels off the car since with no problems.
Seems others have taken a similar approach to me while others have limited the advance by other routes. It seems "All roads lead to Rome!"
#33 | |
![]() Quote:
They did the trick for me. Give them a call, apparently it is a common request. |
