#21 |
Herm, One of the align bore fixtures I have is an old Ammco. Lempco also produced one of these. The fixture uses a false camshaft which you install in the A block and it has two equally distanced swing arms which rotate on the false camshaft and lock onto your boring bar in the fixture to establish the cam to crank center line distance. What is your opinion of these fixtures?
#22 | |
![]() Quote:
#23 | |
![]() Quote:
http://www.model-a-ford-4bangers.com/ |
#24 | |
![]() Quote:
That was a new crank gear from Dan the Man, purchased as a set with his Bronze timing gear.
#25 |
Wish mine were that easy. A few years ago I removed 5 gears from some cranks, and a couple wouldn't even come off using my 20 ton press. I had to heat them with an ox/acc torch and use a puller on a bearing seperator.
#26 |
#27 |
Tom W had earlier told me his tale of woe which is why I have not tried it.
'31 180A Last edited by tbirdtbird; 02-03-2017 at 10:38 AM. |
#28 | |
![]() Quote:
The things that make a (fixed) center distance not work are, Difference in blocks, wear in cam holes, and a large difference in cam gears and main bolt holes, as they are NOT all the same. You can get exact center distance, and gear mesh using a Dial. I lock the cam and what ever gears I use, and leave what ever crank gear loose, and check at 4 points. They will all be different. In the case of Dan's gears, he wants .005 at the largest, so that is where I set his at. A cast gear and fiber has a different setting, and so on, with all the other kinds of gears that I try not to use. This I use to get an exact setting for a cast crank gear and a fiber cam gear. |
#29 |
This is the set up I use for Dan's Gears, and others. They always are set for what you wanted.
#30 |
good pix Herm and thanks for the input
'31 180A |
#31 |
Thanks for the pictures!
