Old 05-15-2010, 07:31 AM   #1
Bob's '31 Cab
Bob's '31 Cab's Avatar
Default Copper intake / exhaust gasket
In replacing my intake /exhaust gasket with a copper gasket, I'am curious as to your opinion of using a copper coat adhesive before installation, or if this is necessary? The manifold has been resurfaced.
As always,
Thanks in advance for your replys.
Bob's '31 Cab.
Bob's '31 Cab is offline   Reply With Quote
Old 05-15-2010, 07:56 AM   #2
peters180a/170b
peters180a/170b's Avatar
Default Re: Copper intake / exhaust gasket
I never did. Just remember when installing the manifold work from the 2 nuts inside and work your way to the 2 outer ones. Alittle at a time. I take it "BOTH"manifolds were resurfaced together as one unit?
peters180a/170b is offline   Reply With Quote
Old 05-15-2010, 08:52 AM   #3
pat in Santa Cruz
pat in Santa Cruz's Avatar
In general I do not use any adhesive with the copper manifold gaskets, unless the block is pitted, as sometimes is the case around the front where water splashed from the leaky pump. In that case, I have found that Ultra Gray RTV works very well and is not affected by the heat. The copper gaskets work very well.
pat in Santa Cruz is offline   Reply With Quote
Old 05-15-2010, 09:02 AM   #4
Mitch//pa
i use the copper gaskets without spray. i also change the studs, nuts and dishwashers
Old 05-15-2010, 09:15 AM   #5
Bob's '31 Cab
Yes it was.
Thank You for your reply.
