Any you boys try those Halagon head lights from "Drake"; if so how did they fit??? Thanks much !!!
Tried a pair several years ago. No matter how may times I tried to align them, there always seemed to be a big dead spot in front of the car. Finally went back to conventional sealed beams.
You can put halogen sealed beams on the '47 like I did on mine. Noticeabley brighter than the regular sealed beams. Available off the shelf at NAPA: http://www.napaonline.com/Catalog/Ca...006_0325911338
Prof. Henry (The Roaming Gnome) ![]() "It is good to have an end to journey toward; but it is the journey that matters, in the end.” *Ursula K. Le Guin in The Left Hand of Darkness |
If those are the Wagner Lighting H6006 unit they are no longer made. they stopped production in 2009. You can find them on the bay or if your lucky at a long time local parts store. My local store had 24 on the shelf in March at $8.99 ea. Then 0 a month later.
I just called my local NAPA store and they have two on their shelf.
If it aint broke, don't fix it! |
#7 | |
![]() Quote:
This one has a pair of the Wagner H6006s They are much brighter than the standard sealbeams. The Courier is 6v pos ground with a generator. There is no problem when running these at night. The ammeter shows about 10 amps charge when these are on at 35 to 50 MPH.
Thank's to all for your aid and assistance with the Halogen question.......Dave
My local NAPA has the H6006 available so I may try a set on my 46. Thanks for the info.
