12-06-2011, 12:19 AM | #1 |
starters
How can I tell the difference between a 30's 4-cylinder starter and a V-8 starter? I think I have a 32-34 starter.
rafter |
12-06-2011, 02:28 AM | #2 |
Re: starters
I beleive that the 3 hole mounting flange is part of the starter on the 4 cylinder and on a 32 - 53 v8 the starter had no 3 hole mounting.
12-06-2011, 09:50 AM | #3 |
Re: starters
The 32-33 4 banger starter I have has 3 screws to mount the starter switch vs A starter with 4 screws. (Has flat copper pad under switch.)
This starter was from a Model B combine engine so it might be different from car/truck. It has a wire cable "pull" instead of the "rod" switch. Last edited by Benson; 12-06-2011 at 11:03 AM. |
12-06-2011, 10:43 AM | #4 |
Re: starters
The 32-34(?) starters have a threaded stud, for the battery cable, in the same
location as the copper pad, as an A. They are same size, bolt pattern, A&B 4banger. The V/8 is longer and bolts up differently. |
12-06-2011, 11:23 AM | #5 |
Re: starters
Benson,
Have some Coffee, and get back to me!! LOL |
12-06-2011, 11:43 AM | #6 |
Re: starters
12-06-2011, 02:15 PM | #7 |
Re: starters
That's a myth, a model A 6 volt starter has 2 field coils in parallel with the other 2.
For 12 volts, all 4 field coils are wired in series. If you operate a 6 volt starter on 12 volts it MAY work for a while, But how long! Best to buy new field coils wired for 12 Volts. |
12-20-2011, 09:07 PM | #8 |
Re: starters
32 B starter has 3 screw switch as Benson stated.33 B starter has threaded post on bottom side of starter. 33s had switch mounted on steering box with short cable to starter.I also believe there was 2 types of s-switch in 32.
