Old 05-25-2024, 10:47 PM   #1
aussie merc
aussie merc's Avatar
Default 39 mercury towbar /hitch
looking for drawings -plans-photos of a tow hitch for a 39 mercury can anyone help Thanks
aussie merc is offline   Reply With Quote
Old 05-25-2024, 11:23 PM   #2
nelsb01
nelsb01's Avatar
Default Re: 39 mercury towbar /hitch
The basic one that I have uses angle iron that is shaped into a Y.
You will need to remove the front bumper and bumper brackets as there are are 2 steel plates that mount to the frame where the bumper brackets were removed. You can use the bumper bracket bolts. Then the tow bar attaches to the steel plates.
I use C-clamps to attach temporary tail lights to the rear bumper brackets and run the wires to the tow vehicle. You must have the steering lock in the on (unlocked) position so that the front wheels track while being pulled.
I hope you get the explanation of this.
It was made by a friend and it worked for me over the years as long as the bumpers were on brackets.
nelsb01 is offline   Reply With Quote
Old 05-26-2024, 03:11 AM   #3
aussie merc
sorry wrong end want to tow small trailer /camper Thanks anyway
Old 05-26-2024, 10:09 PM   #4
kiwi nz
My 37 had steel channel running for and aft with a welded plate to bolt to the spring u bolts and a piece of flat bar running across between the inner bumper bolts welded to the channel with a tab.
This was to get the height correct for it to pass through under the bumper to the rear of the car, a tow ball was bolted directly to the protruding channel.
It was obviously not professionally made as the finished result was not very elegant
I would do a far neater job if was make myself one, but when I do get the car running again I do not plan to do any towing.
I hope that helps.
Geoff
kiwi nz is online now   Reply With Quote
