Old 05-25-2024, 06:59 PM   #1
Epetek1
Default electrical charging problem
hadn't run car since last year, car started and ran fine yesterday and charging 10-20 0ver, horn worke and showed discharge. Today car started and ran well but battery no longer showed a charge. It did show a discharge when horn hit but never went above zero on ammeter when running and accelerating.
Any ideas appreciated. here or [email protected]
thanks in advance,
Pete K
Epetek1 is offline   Reply With Quote
Old 05-25-2024, 08:18 PM   #2
Gary WA
Gary WA's Avatar
Default Re: electrical charging problem
thanks in advance,
Pete K
Have a load test done on battery! and check your cut out may be stuck! There will be many more suggestions!!
www.whidbeymodelaclub.com
Old 05-25-2024, 09:22 PM   #3
mass A man
mass A man's Avatar
Try just cleaning the commutator of the generator. A small cloth with solvent, no metal sharp tools of course. --Pete K.
mass A man is offline   Reply With Quote
Old 05-26-2024, 06:38 AM   #4
nkaminar
nkaminar's Avatar
Another possibility is that the generator needs re polarization. The field magnets may have lost their residual magnetism.
nkaminar is online now   Reply With Quote
Old 05-26-2024, 07:46 AM   #5
Jim/GA
Jim/GA's Avatar
Pete, you don't say if this is an original generator with mechanical cut out, generator with EVR and/or diode cut out, or alternator.
I would diagnose each of those slightly differently.
Jim Cannon
"Have a Model A day!"
Old 05-26-2024, 01:01 PM   #6
Epetek1
original generator and cutout. pete
Old 05-27-2024, 12:07 AM   #7
Jim/GA
Jim/GA's Avatar
You will need an assistant...
Get the engine running on a fast RPM. Have your assistant watch the ammeter.
You take a short piece of wire and "jump" between the two terminals of your cutout. Be careful to only touch the cutout terminals and not the cutout case (cover) because it is grounded.
Ask your assistant if the ammeter now shows a charge. If it does, the cutout is not working. If it still shows no charge, the problem is in the generator. Now you know where to look.
Don't leave that jumper wire on. It's just for a quick test when the engine is on a fast idle.
Hope that helps.
Jim Cannon
Old 05-28-2024, 07:23 AM   #8
Bob Bidonde
Bob Bidonde's Avatar
These slides embellish Jim/GA's advice. The jumper in the middle slide should cause the Ammeter to react. I urge you to make the Ammeter's cover removable for trouble shooting.
File Type: jpg Cutout Cover – Make It Removable 179kb.jpg (59.9 KB, 21 views)
Bob Bidonde
Old 05-28-2024, 08:14 AM   #9
Jim/GA
Jim/GA's Avatar
Not the Ammeter's cover, the Cutout's cover.
Bob needs another cup of coffee before posting replies.
Jim Cannon
Old 05-28-2024, 08:33 AM   #10
ndnchf
ndnchf's Avatar
The covers are spot welded on, usually with 2 spot welds, except the early type with tab terminals that have 4 spot welds. Filing the edge alone won't be enough to remove the weld. If you look close on the sides of the cover, you can see the spot weld. It goes maybe 1/8" - 3/16" down the side. You don't want to file it down that far.
I refurbish a lot of cutouts. To remove the cover I grind the weld edge just flush. Then use a carbide bit in a Dremel to grind the inside surface of the spot weld until it is through or almost through the inner surface (the cutout base). Then turn it upside down on a solid surface, and use a tiny flat blade chisel (made from a very small flat punch) and hammer to split the weld completely. Then the cover can be removed.
My video explains this and how to test and service a cutout.
https://youtu.be/rnuukBeJ6Zs?si=_OBDwb75aJ3jXF_7
ndnchf is offline   Reply With Quote
Old 05-28-2024, 11:22 AM   #11
Y-Blockhead
Y-Blockhead's Avatar
Excellent video! Thanks for sharing.
