Old 05-24-2024, 07:19 PM   #1
jtminor
Default Tail light connectore
Can someone please tell me how to connect these tail light wires.
jtminor is offline   Reply With Quote
Old 05-24-2024, 07:28 PM   #2
petehoovie
petehoovie's Avatar
Default Re: Tail light connectore
Old 05-24-2024, 07:58 PM   #3
cmbrucew
cmbrucew's Avatar
They look like aftermarket Fainstock bullets. They may plug into original Ford connectors.
Bruce
Works good
Lasts long time
cmbrucew is offline   Reply With Quote
Old 05-24-2024, 09:40 PM   #4
jtminor
anyone know where to get connectors
Old 05-24-2024, 11:41 PM   #5
restoman
Bob Drake had them recently, also probably Third generation.
restoman is offline   Reply With Quote
Old 05-25-2024, 07:33 AM   #6
tubman
tubman's Avatar
I will note that the "bullet" connectors shown look different from the original Ford units. They will probably work, but.....
Old 05-25-2024, 09:06 AM   #7
FortyNiner
FortyNiner's Avatar
Napaonline.com
Old 05-25-2024, 09:14 AM   #8
Kube
Kube's Avatar
Yep. They will work but you will need to grind down the diameter a bit. As is, they will not fit the connector.
Old 05-25-2024, 09:15 AM   #9
busmania
busmania's Avatar
I was able to get them to fit recently without grinding. They are just tight.
40 ford coupe Build -https://www.jalopyjournal.com/forum/...coupe.1277406/
busmania is offline   Reply With Quote
Old 05-25-2024, 04:28 PM   #10
JayChicago
JayChicago's Avatar
Aren’t those the light bulb contacts? Don’t look like bullet connectors. Wire looks correct for Ford taillight.
Old 05-25-2024, 04:34 PM   #11
vincent
They do look like the british Lucas connectors that were used on all british motorcycles between the 50s and 70s - should be easy to find.
vincent is offline   Reply With Quote
