05-23-2024, 03:39 PM | #1 |
Stake bed gate hinges
Does anyone know of reproduction or have an original set of side gate hindges for the early Ford stake beds.
05-23-2024, 04:44 PM | #2 |
Re: Stake bed gate hinges
Might check on the AA site. http://forums.aa-fords.com/
05-23-2024, 06:12 PM | #3 |
05-23-2024, 07:23 PM | #4 |
I saw some in a welding equipment store that looked about right. Newc
05-23-2024, 08:13 PM | #5 |
there registration is f up.
05-23-2024, 08:13 PM | #6 |
05-23-2024, 08:15 PM | #7 |
Could you modify these to make what you need?
https://www.buyersproducts.com/produ...nector-set-753 |
05-23-2024, 08:22 PM | #8 |
Check Tractor Supply, Bigger Ace hardware stores. I built a stake bed box many years ago and found the hardware at those stores. Also every year when I go to the LARS and am driving around mostly Pomona I see all these stake bed trucks with similar black powder coated hardware?
05-23-2024, 08:53 PM | #9 | |
05-23-2024, 11:03 PM | #10 |
i could. Would like to have one piece to copy.
05-23-2024, 11:04 PM | #11 |
they would work, for sure. Thats what my fathers rack truck had.
05-24-2024, 08:24 AM | #12 |
The Model AA truck parts didn't change through the Early Ford V8 era. To help in looking for parts, the part numbers for the hinges are AA-186304-B and AA-186405-B. You need a total of 8 of each type.
Northern Classis Trucks, now out of business, used to make these parts. I don't know of any current supplier of the hinge brackets. I can make an accurate drawing from a couple of original hinge brackets and send to you if that will help. Attached is a picture of the two types needed.
1935 157" 1 1/2 ton stake truck undergoing full original restoration 1936 131 1/2" panel truck rescue preservation Author of the 1935-1936 Ford Model 51 V8 Truck book published by the Early Ford V8 Club of America |
05-24-2024, 11:18 AM | #13 | |
