I have reached the point where it is time to install the brake rods. All other brake parts have been replaced as necessary. Is there a paper written which gives the lengths of each brake rod and the proper sequence of the installation?
Should all the brake adjusters be completely backed off? Are all the brake rod length adjusters located at the brake cross shaft? Thanks for your help, Ed |
#2 | |
![]() Quote:
For the e-brake rods, no clicks on the handle (full forward) should have the drums running free, one click should start to have drag, two clicks should give significant but equal drag on the rear wheels. A very hard pull to the third click should lock both wheels up solid. Check both going forward and backward. You will likely have to do this after the car is running. Adjust the rods accordingly.
JayJay San Francisco Bay Area ------------------------ 1930 Murray Town Sedan 1931 Briggs S/W Town Sedan Last edited by JayJay; 05-23-2024 at 01:41 AM. |
At one point in the production of the Model A the brake rods were non adjustable. Once they are set to the correct length they should not be adjusted. The Service Bulletins shows the correct length.
Set the length of the brake rods in the front so that the levers are 15 degrees angled forward. In the rear set the brake rods so that the levers are angled 5 degrees towards the rear. Do not change the length of the brake rods to adjust the brakes. Use the adjusters. If you cannot get the brakes to come into adjustment in the front, add one or more "pills" (shims) under to rods that go through the king pins. Follow JayJay's advice for adjusting the emergency brakes.
A is for apple, green as the sky. Step on the gas, for tomorrow I die. Forget the brakes, they really don't work. The clutch always sticks, and starts with a jerk. My car grows red hair, and flies through the air. Driving's a blast, a blast from the past. Last edited by nkaminar; 05-22-2024 at 05:33 PM. |
Don't forget to install the "anti-rattlers" on the brake rods.
Ed, as a Model A "Novice" myself, here is an excellent youtube video that I used to quickly advance my knowledge of the Model A brake systems. You can purchase copies on CD from the vendors, but someone has posted it on the internet.
I own a copy of the film and have watched it at least a dozen times. On occasion, I review it again. Read the Les Andrews red book and study this video. When the presenter is assembling the parts to the car, use the stop and back button and watch exactly the order and position of the parts as he places them. Sequence and angles matter. The parts can be placed by hand if you're a younger person, but I use the "pistol grip" looking brake shoe tool that is available from Mike's Affordable and other vendors. It makes installation of the shoes and springs very easy. Eye protection is advisable when placing the springs, especially the e-brake springs on the rear. I tie a ribbon of colored material to those 4 springs as when they leave unexpectedly, they can disappear into thin air, LOL. I found when researching the how-to's of Model A brakes that there are different opinions on how to adjust them. The Ford Service Bulletins describe how the dealer was supposed to do it, and this video has a good description of that. It does however, include a description of when to adjust the lengths of the rods to remove operational slack in the system. In my mind, adjusting this slack out of the rods moves the braking action closer to the top of the pedal than is otherwise achieved. I am a novice here, but we have driven our coupe ~ 20,000 miles in 3 years time. As the components of the brakes have worn, I've certainly made adjustments to the adjustment wedges, but I've also taken up slack in the rods. The linings are nearing their service life, yet the car stops as it should, when the pedal is pushed. I use an infra red temperature tool to make fine point adjustments to the brakes after working on them or having the drums off to grease the bearings. Good luck and have fun, it's all about the "Model A Experience". https://www.youtube.com/watch?v=3GFMJ7iiWiI&t=4s
"It ain't what you know for certain that gets ya in trouble. It's what ya know for certain that just ain't so!" ![]() |
--------------------------------------- 1929 Model A Tudor "Stay away from negative people, they have a problem for every solution" Model A Ford Club of America Model A Restorers Club Motor City A's Club |
#7 | |
![]() Quote:
#8 | |
![]() Quote:
Screen shot from video: Worn or broken keys can cause many problems. Taper end of key toward differential with the taper down. (Keep a spare key in your tool box.). Last edited by Y-Blockhead; 05-23-2024 at 02:32 PM. |
Thanks Y-Blockhead, contacted Steve, and the parts will ship out today.
Blockhead, I made the same mistake watching the video again this morning. Back up just a bit. The key has a bevel on two ends, opposite sides. Almost every sentence the presenter says is important.
![]() I'd like to have that chassis.
Les Andrews book gives a length to set the brake rods to. Then it says to pull the rods/levers to take all the slack out of the system, which changes the length. Then if you watch Paul Shinn's video he sets the wedge and then monkeys with all the brake rod lengths to get even braking.
What's the proper length? When you find out, let me know. |
