05-07-2024, 07:24 PM | #1 |
55 ford victoria shift collar
I'm trying to find a diagram showing how the shift collar and shifter goes together. It's an automatic. Thanks
05-08-2024, 12:59 AM | #2 |
Re: 55 ford victoria shift collar
It seems to look similar to the 1957 version, the thinner column post should have like a finger tube with a hole, there is a spring and two little caps that go into the tube. there is a rubber insulator that goes on the top of the end of the shift arm, that assemble gets wiggled into the finger hole. I'll about taking pics of mine. It was what a wedge in fit when I replaced the rubber on mine. I want to say it's all held with the spring pressure.
See pic Last edited by Abe Lugo; 05-08-2024 at 01:04 AM. |
05-08-2024, 07:39 AM | #3 |
Thanks so much! My shop manual didn't have any info.
05-23-2024, 01:39 PM | #4 |
I'm trying to install the lever. I have the spring and cups. Is the rubber piece at the roll pin what u r referring to,Abe
05-23-2024, 09:40 PM | #5 |
If memory serves....not at home now
Insert shift lever with rubber fully greased---- Above the seated area. Insert shift lever upside down rotate 180 Insert long spring then cap, short spring then cap push down on top crown with screwdriver, push lever in on top of cap Seat rubber, install pin |
05-23-2024, 09:42 PM | #6 |
Insert shift lever with rubber fully greased---- Above the seated area. Insert shift lever upside down rotate 180 Insert short spring then cap, long spring then cap push down on top crown with screwdriver, push lever in on top of cap Seat rubber, install pin |
