#81 |
Mike85212, wish I lived closer to you! I think those 16" look bitchin on a Vicky!
#82 |
Fredski53....you should take some time off and come to the desert for a while in the wintertime and get out of the cold snowy weather!
#83 |
Mike, if I was to show this post to the wife, I know she would jump at the chance to go somewhere warm! Question, when you had the 16" wheels on your Victoria, did the tires rub the front brake rods? How wide are the tires?
#84 |
I had mine done at Pico Wheel. 818-421-6102
1921 Runabout 1930 Tudor Early 1930 AA Speed costs money. How fast do you want to go? ![]() |
#85 |
Widening the wheels seems like a lot of expense for not much gain. I have stock 5 inch wide 35 Ford wheels on which I mounted 225/75R16 tires. The tires don't like at all oversized for the rims and the tread width is 7 inches. Unless you're looking to install 10-11 inch wide tires, the stock rims work fine.
AL in NY |
#86 |
#87 |
Hi Fred, The tires are 6.5 X 16.
No, they did not rub anything. Obviously we all know that there are a lot of cars out there running 16” wheels I think it really comes down to personal preference. To say that there is a right or a wrong is not correct. Mike |
#88 |
Got the 16" wheels on and the 155/90-16 spares too.
#89 |
#90 |
#91 |
I don't know what it costs to have a wheel widened but you can have new ones made in a variety of widths and diameters. They are not cheap but they are brand new and sealed for use with tubeless tires. I've had two sets made by the "wheel smith" out of california. I have a dozen real nice original '35's, two of which will be used for the spares on my DD. I know that stock '35's are dirt cheap compared to brand new ones but if you want wider than stock, going new and running tubeless is an option.
#92 |
I run 35 ford wires tubeless with no issues, I do use metal valve stems. At fifty bucks a tire crowning is a non issue,a wide footprint distributes the low weight just fine.If I get five years out of the tires thats 40 bucks a year cost..how cheap does it have to be?
#93 |
![]() ![]() ![]() ![]() Last edited by Madster; 09-27-2022 at 11:40 AM. |
#94 |
#95 |
That's the size I've been considering. Do you find that they ride okay, not too hard? Are you running tubes or tubeless? Thanks
#96 |
I ran 6.00 X 16 on my 31 Coupe for over 50 years. No regrets, good ride, better traction and stopping. Now I went back to 19" and have a set of 5 16" wire wheels, if anyone needs them.
#97 |
Spare fits into the well without change?
I love a girl and "Ruby" is her name, ChaCha |
#98 |
#99 |
The tires on my Coupe are stock 1932 size 5,25x18".
Bob Bidonde |
