Old 05-19-2024, 08:41 PM   #1
Amctavish77
Default 1931 Model A not turning over
Hi all, I have a ‘31 Tudor that’s all stock and I recently rewired it front to back with a kit from Mike’s. I’m still waiting on a headlight switch housing but I fired the car sans headlight/tail lights and it fired with no issues. Drove it all over the place a couple days later with no problems at all. I went to fire it and take to to a car show a couple days later and it turned over 2 or 3 rotations and then wouldn’t turn over anymore. When I hit the foot switch, I get nothing, no noise, no attempt to rotate, nothing. I haven’t put a meter on anything yet but the fuse was ok and the starter isn’t locked up.
So my question is, what do I need to be looking for? Could the starter be bad or is there something else I need to look at. I’m hoping I don’t need to chase another electrical gremlin as that’s why I rewired the car to begin with!!
Any help any one can offer will be greatly appreciated! Or, if you’re in the Fresno/Clovis area and can help out in person, I’ll be happy to buy lunch, provide beer, or a monetary donation for your time to get me back up and running!!
Amctavish77 is offline   Reply With Quote
Old 05-19-2024, 09:52 PM   #2
J Franklin
J Franklin's Avatar
Default Re: 1931 Model A not turning over
Does it turn with your hand crank?
Old 05-19-2024, 09:56 PM   #3
47topless
47topless's Avatar
How do you know, for sure, that the starter isn't locked up?
47topless is offline   Reply With Quote
Old 05-19-2024, 10:16 PM   #4
J Franklin
J Franklin's Avatar
Does it turn over with the hand crank?
Old 05-19-2024, 10:17 PM   #5
ArtimusGordon
Turn ON HEADLIGHTS! If they don't work start checking the battery and connections.
ArtimusGordon is offline   Reply With Quote
Old 05-19-2024, 10:26 PM   #6
J Franklin
J Franklin's Avatar
Good idea!
Old 05-19-2024, 10:40 PM   #7
Amctavish77
Hey guys, thanks for the response. The car currently has no headlights as I am waiting on a new switch (the one at the base of the steering column). The wafer on my switch was trashed. So, I haven’t hooked up the wiring for the lights to my alternator yet.
I have turned the motor over with the hand crank but not started it that way. It turns over just fine. I have also put the car in 3rd gear and rocked back and forth but no change.
Old 05-20-2024, 03:47 AM   #8
Rob Doe
Do you have a voltmeter? A test light? A hydrometer to test the battery? The Les Andrews red book?
Make sure your battery cables are clean, bright and tight at both ends. On a stock wired Model A, a failed ground at the frame kills everything until the car is running.
"It ain't what you know for certain that gets ya in trouble. It's what ya know for certain that just ain't so!"
Rob Doe is offline   Reply With Quote
Old 05-20-2024, 07:04 AM   #9
47topless
47topless's Avatar
If you don't have the tools to test the battery yourself, just remove it, (take a photo of how it was installed first) and take it down to an auto parts store and have it tested there. They don't charge for this. If battery tests good, reinstall and follow the suggestions above regarding connections etc.
Good luck, wish I lived closer to you to help.
Old 05-21-2024, 06:27 AM   #10
Ayers1
Ayers1's Avatar
Sounds like the starter switch could be bad. You could pull it off and touch the batter cable to the post on the starter and see what happens. If it turns over then the switch is bad.
Ayers1 is offline   Reply With Quote
Old 05-21-2024, 06:58 AM   #11
nkaminar
nkaminar's Avatar
If you do the above test and the starter does not turn over, then the starter is bad.
Old 05-21-2024, 10:41 AM   #12
J Franklin
J Franklin's Avatar
Or the bendix is stuck. OOPS! I see you could turn it by hand.
Old 05-21-2024, 02:44 PM   #13
gdmn852
gdmn852's Avatar
Dead battery likely suspect. You jump a very short time from a 12 volt car if it starts quickly. A small battery charger is also useful, just make sure it can charge 6 volt.
gdmn852 is offline   Reply With Quote
Old 05-21-2024, 10:45 PM   #14
Amctavish77
All, thank you for the great tips and advice. I finally got around to yanking the battery out and realized it was 8 years old! And while it would hold a charge, there was no load capacity so long story short, new battery fixed the issue! I feel stupid overlooking something so obvious!
Thank you all for your help; I really appreciate it!
