Old 05-11-2024, 08:24 AM   #1
P.S.
Default Electronic vs. mechanical 6 volt turn signal flasher
https://youtu.be/G7UePX5BowE
left 4-ways on for filming. Roasted 2 electronic flasher units. Mechanical one still working after 2 hours of continuous operation. Why are the new electronic ones so fragile?
2024 MAFCA Technical Director
P.S. is offline   Reply With Quote
Old 05-11-2024, 10:24 AM   #2
oldspert
oldspert's Avatar
Default Re: Electronic vs. mechanical 6 volt turn signal flasher
Possibly they are originally designed for 12 volt systems and 6 volt creates too much resistance or heat for them to last.
oldspert is offline   Reply With Quote
Old 05-11-2024, 12:09 PM   #3
Banditorama
What flasher unit were you using? Were the bulbs you had in there LED or incandescent?
Banditorama is offline   Reply With Quote
Old 05-11-2024, 12:15 PM   #4
ModelA29
ModelA29's Avatar
Unlike your screwdriver they are not American made.......
ModelA29 is offline   Reply With Quote
Old 05-11-2024, 02:53 PM   #5
P.S.
Hahhaaa!! That has to be it.
Old 05-11-2024, 02:54 PM   #6
P.S.
The electronic one sold by all the vendors. Made of chinesium.
Old 05-11-2024, 04:49 PM   #7
Banditorama
Send them back. My old "Chinesium" flasher relay I bought off Amazon a year ago is still kicking. None of the vendors seem to give any kind of info on the flashers they have, they should provide a spec sheet for them.
Old 05-11-2024, 06:07 PM   #8
P.S.
Had not thought of that. Thanks!
Old 05-11-2024, 06:36 PM   #9
Synchro909
Synchro909's Avatar
I noticed in his video, Paul quotes a number to identify what globe he was using. Those numbers mean nothing to me (or anyone else I know). Is there a system to them, if so, what is it.
Globes here are marked by voltage and wattage. Eg, 12v/21w is clearly a 12 volt globe and 21 watts. (What is a CP?)
They say America and other English speaking countries are divided by a common language but there are times I wonder whether we do in deed, speak the same language!
Old 05-11-2024, 08:06 PM   #10
Banditorama
CP = candle power
It's an archaic form of measuring light intensity. We don't use it here in the states anymore either, we use lumens now. We also don't call them globes, we call them bulbs.
Old 05-12-2024, 02:03 AM   #11
Synchro909
Synchro909's Avatar
CP = candle power
Two peoples separated by a common language! Don't start me on cotter pins!
