Old 10-23-2023, 04:10 PM   #1
amodel25
amodel25's Avatar
Default Re: PCV valve for my H six ?
On my '51 226 in my 2 door sedan I unbolted the vent tube from the valve train cover completely and installed a grommet and PVC valve from a V8 '72 Chevelle 350. the grommet fits snug as does the valve. I tack welded a piece of plate on the inside of the valve cover to prevent oil being sucked out of the valve spring chamber. Ran a hose from the PVC valve to the threaded vacuum connection on the intake manifold. Air is pulled in through the oil filler cap and exhausted out through the intake manifold.
Has worked great for 20+ years.
amodel25 is offline   Reply With Quote
Old 10-23-2023, 04:25 PM   #2
GB SISSON
GB SISSON's Avatar
My inlet and outlet's the same as yours, but I'm quite sure your grommet makes a tighter connection than I got by connecting to the road draft tube. That strange angled machine screw into the eliptical hole on the valve cover could have been better engineered. (And I keep resisting the urge to go look at that ford jeep.)
Old 11-02-2023, 06:02 PM   #3
Mercy
Mercy's Avatar
GB, how did your surgery go? Are you back under the hood yet?
Mercy is offline   Reply With Quote
Old 11-02-2023, 08:40 PM   #4
GB SISSON
GB SISSON's Avatar
Back at it, for real. I have a week of free time for trucks because my current woodworking project got stalled (again). We like to say this gal "Doesn't know what she wants, and she won't be happy 'til she gets it".
Old 11-04-2023, 06:33 AM   #5
38 coupe
38 coupe's Avatar
Good to hear you are doing well.
I can't believe I haven't heard that saying before, it's great. I'm going to use that.
