06-07-2021, 11:13 AM | #1 |
spark plug recommendation
Guys,
I'm running Autolite 216's in my 286. Under sustained highway driving I think the 216's are breaking down, the motor begins to run rough. The rough running gives the effect similar to a wheel out of balance. All plugs are a reddish brown...the motor runs an L100 cam, lots of comp and a Stromberg 48 with # 50 jets. I've always preferred Autolites but I'm open to suggestions. The Autolite tech guy was no help. Charlie ny |
06-07-2021, 11:36 AM | #2 |
Re: spark plug recommendation
I use NGK B6L gapped at .025.
06-07-2021, 12:00 PM | #3 |
X2 on the NGK
06-07-2021, 12:08 PM | #4 |
Another NGK fan here! B6-L for short reach and B5-ES for longer reach like Baron or Flatattack.
RIP Tyler... My Son, Helper & Best Friend. Feb '78 to Father's Day '10. www.97-express.com ~ [email protected] |
06-07-2021, 01:06 PM | #5 |
After trying the H-10 and the 216 with not the best of luck I converted to the NGK and all is now good. The NGK B6L is the equivalent heat range to the H-10 and 216. The B-4-L can also be used if a slightly hotter plug is needed. With NGK the lower the number the hotter the plug for a gap with 12 volts go to .035
Ronnieroadster
I use the F word a lot no not that word these words Flathead , Focus and Finish. "Life Member of the Bonneville 200 MPH Club using a Ford Flathead block" Owner , Builder, Driver of the First Ford Flathead bodied roadster to run 200 MPH Record July 13, 2018 LTA timing association 200.921 in one and a half miles burning gasoline. First ever gas burning Ford flathead powered roadster to run 200 MPH at Bonneville Salt Flats setting the record August 7th 2021 at 205.744 MPH |
06-07-2021, 02:15 PM | #6 |
06-07-2021, 03:22 PM | #7 |
I run the NGK B4L in my 286 CI Flathead. Seems to have eliminated my carbon buildup.
06-07-2021, 03:47 PM | #8 |
Please help a Dummy here. I have a 1941 stock Flathead in a Coupe. What number NGK should I buy?
06-07-2021, 04:57 PM | #9 | |
B6L unless it is a tired oil burner,then B4L.
"It don't take but country smarts to solve the problem" (Smokey Yunick) '41 Merc Town Sedan / 260" 8CM engine '66 Fairlane four door / "warmed up" 302 |
06-07-2021, 05:27 PM | #10 |
What does the reddish brown color on the insulator tell me ?....I'm thinking lean. ?
Charlie ny |
06-07-2021, 06:29 PM | #11 | |
Ronnieroadster
06-07-2021, 08:41 PM | #12 |
Thanks Ronnie......
NGK's on the way, very eager to file a report. Charlie ny |
06-07-2021, 09:02 PM | #13 |
Back in my snowmobiling days, reading plugs was very important. We wanted to go as fast as possible, and that meant "leanin' 'em down" as far as it was safe to go. Of course, if you went too far, you ended up with a hole in a piston, which wasn't good. In those days, we said that if you bought a Hershey Bar and broke a piece off, the color of the broken part was what you wanted your plugs to look like.
These days, gas isn't what it used to be, and Hershey Bars probably aren't either. |
06-07-2021, 10:38 PM | #14 |
It's close to Hershey chocolate.
Charlie |
06-08-2021, 07:49 AM | #15 | |
06-08-2021, 08:16 AM | #16 |
Charley: Back in the day with a 239 with my foot in it, I ran H-9 plugs with good success. The stock jet for the Stromberg 48 is .048 and I am thinking your use of .050 is too rich, hence the color of your plugs. JMO.
06-08-2021, 09:25 AM | #17 |
Hi Bill,
The motor is a 286 cu in 8BA......L-100 cam.....max comp EAB heads. The rule of thumb is no more than 2 #'s over stock so there's where I stopped. I will definately check the color of the NGK's after another run on the freeway. Charlie ny |
06-08-2021, 09:46 AM | #18 |
NGK plus they are indexed, meaning the hexes are all
oreneted in the same position. G.M.
www.fordcollector.com |
06-08-2021, 10:29 AM | #19 |
I would. That color matched the pictures of the desired color in an old Motor manual I had. It's much easier to describe a Hershey bar to most people than to carry motor manual around with me every place I went.
06-08-2021, 10:52 AM | #20 |
Coco brown is a good color on spark plugs but they can be a lighter shade toward gray and still be good. White or yellow would be too lean and of course black is too rich or too much oil loss into the cylinder.
The best way to check them is to motor down the road for a good bit and then shut down the engine and coast to a stop. This will give a good running color. If the engine is idling too long then the color can change on you. |
