Old 02-16-2020, 08:56 PM   #1
Mad Mac
Default Oil - again
I have just bought some Havoline 20-W50 oil for my Model A. I bought it because it says "better wear protection for older engines". But then I noticed it also says API SJ. I recall reading somewhere that it should be API SC for Model As? I know some guys think its not important but I want to get it right if possible.
Mad Mac is offline   Reply With Quote
Old 02-16-2020, 10:38 PM   #2
Ernie Vitucci
Default Re: Oil - again
Good Evening...Model A Engines should have SN engine oil according to a recent article in Model A Times...Give it a read and then decide...Ernie in Arizona
Old 02-16-2020, 10:47 PM   #3
CWPASADENA
CWPASADENA's Avatar
The 20-W50 oil will work just fine in your Model A. This is way better stuff than what was available when your Model A was new.
Chris W.
CWPASADENA is offline   Reply With Quote
Old 02-17-2020, 12:57 AM   #4
M2M
M2M's Avatar
SJ is more than good for an A. SC oil will be hard to find and expensive if you do.
M2M is offline   Reply With Quote
Old 02-17-2020, 01:58 PM   #5
Mad Mac
Yes it was SN, not SJ and I think you are correct.
Thanks,
Mac
Old 02-17-2020, 09:14 PM   #6
Conaway2
Conaway2's Avatar
My engine rebuilder - with a national reputation - suggested to use Valvoline VR1 Racing oil - 10W-30, with ZDDP Plus additive to restore zinc and phosphorus levels to the oil to prevent premature wear to the cam and tappets. It made sense to me and really doesn’t cost more, so I follow the recommendations. Amazon sells both products.
Jim
Conaway2 is offline   Reply With Quote
Old 02-17-2020, 09:20 PM   #7
M2M
M2M's Avatar
Thanks,
Mac
The cheap oil at Walmart is SN.
Old 02-19-2020, 04:44 PM   #8
captndan
captndan's Avatar
Rotella T and don't worry about the little stuff.
captndan is offline   Reply With Quote
Old 02-19-2020, 05:53 PM   #9
30 Closed Cab PU
Zinc is not needed after break in on the A motor, zinc was added later due to higher engine speeds requiring stiffer valve springs to prevent valve float.
Old 02-22-2020, 11:17 AM   #10
pjdeb
pjdeb's Avatar
What Rotella do you use? T4?
pjdeb is offline   Reply With Quote
Old 02-22-2020, 12:01 PM   #11
Y-Blockhead
Y-Blockhead's Avatar
Jim
Valvoline VR1 Racing Oil already has high amounts of Zinc and Phosphorus. Adding ZDDP + is not needed and a waste of money.
Old 02-22-2020, 01:50 PM   #12
30 Closed Cab PU
If you do a search, tons of discussion on this. I consider this a good thread.
https://www.fordbarn.com/forum/showthread.php?t=159816
Too much Zinc is bad, more is not better.
I use Rotella T4, has some zinc, might help, but should do no harm unless too much zinc is added. I personally do not believe Zinc is required in the Model A motor..
Opinions vary.
Old 02-22-2020, 04:42 PM   #13
M2M
M2M's Avatar
Talking Re: Oil - again
Rotella is the little stuff.
