06-23-2019, 05:02 PM | #1 |
Engine problem - maybe broken cam
Just got back from a shortened drive. At idle, the engine made a sudden loud "clack", followed by severe knocking/banging. The sound eased up pretty quick, and the engine kept running. I shorted the front two plugs and it doesn't seem to make a difference. Shorting the rear two plugs causes a noticeable drop in RPM. Seems like the front two cylinders aren't firing. Is camshaft breakage common?
I'll do some more troubleshooting and pull the head soon. |
06-23-2019, 05:12 PM | #2 | |
Re: Engine problem - maybe broken cam
06-23-2019, 05:29 PM | #3 |
What Y-blockhead said.
Cam breakage is very rare. Before pulling the head I'd recommend looking inside the valve cover and doing a compression test. You may end up removing the side timing cover and looking at the cam gear. I check everything I can before pulling a head. |
06-23-2019, 05:53 PM | #4 |
Is the engine idling now the same as it did before the "bang"?
Are you shorting out both front plugs at the same time, then both rear plugs at the same time or one at a time? I can't see any reason to pull the head now. What are you expecting to find if you do?
All steel from pedal to wheel |
06-23-2019, 06:18 PM | #5 |
Take out the plugs and make sure there is compression in each cyl. You may find one or two with no compression. If so, drop the pan and look for broken pieces. Good luck.
06-23-2019, 06:24 PM | #6 |
This may give you a direction to go. I also agree, not a broken cam. My opinion, Chris W. |
06-23-2019, 06:35 PM | #7 |
The model A&B cam shafts are forged steel not cast iron like most later cams. Its not likely that a forged cam could or would break .
06-23-2019, 08:01 PM | #8 |
Sounds possibly like a broken rod.
Pull the first two plugs and make sure the pistons are moving up and down. If not, drop the pan, go from there. The original cams are tough, we have welded on them and back ground the base circle way down into the cam, nothing broken even up near 7k revs. J
As Carroll Smith wrote; All Failures are Human in Origin. |
06-23-2019, 08:27 PM | #9 |
Wouldn't a broken rod continue to make noise as the engine was run?
06-24-2019, 12:40 AM | #10 | |
06-24-2019, 08:22 AM | #11 | |
I sure hope this is not the case, but OP description of "the engine made a sudden loud "clack", followed by severe knocking/banging. The sound eased up pretty quick, and the engine kept running" describes a typical rod separation. Could be flywheel or clutch but that wouldn't explain the front cylinders not responding. Flathead motors can't drop a valve into the piston either, so that is out unless this is a OHV motor, OP didn't mention that. I wish the best of luck to the OP here, take the time to properly diagnose and let us know what happened. John
06-24-2019, 10:12 AM | #12 |
More than likely the problem is a broken piston skirt . The original pistons had a split skirt , all the way from the oil ring to the bottom of the skirt . I've seen a few model A engines drop a piece of piston skirt into the dipper tray . When this happens , the rods hit the broken piece, make a hell of a knocking sound and then sort of settle down . The engines would still run but skipped on the broken piston cylinder . It could be something else but I can't see a forged model A camshaft breaking or a connecting rod . Model A engines unless highly modified are low compression low RPM engines .
06-24-2019, 10:36 PM | #13 |
Time to drop the pan...pulled the valve cover and all seems normal there. Piston skirt or rod sounds likely...it was a lot of bad noise, not something small.
