03-11-2019, 04:02 PM | #1 |
Oil Pan baffle
I had to take my oil pan off because the threaded ring for the drain plug was spinning and not allowing the drain plug to come out. I've got to fix that, but I'm wondering how the oil pan baffle comes out of the pan. It appears to be just held in by "bumps" on the sides of it that fit into similar recesses in the sides of the pan. But it seems to be too tight for only that. Is there a trick to getting the baffle out?
03-11-2019, 04:06 PM | #2 |
Re: Oil Pan baffle
Several threads about that, many just drop it about 6 feet on to the ground. I just grab it in both hands and whack it flat on the wood bench
Bill Worden 1929 Roadster 1929 Briggs Town Sedan 1930 Closed Cab pickup Smith Motor Compressor 1951 Ford F1 High Desert Model A's |
03-11-2019, 04:14 PM | #3 |
Re: Oil Pan baffle
03-11-2019, 04:28 PM | #4 |
Re: Oil Pan baffle
Baseball bat --- handle end into oil pump hole, other side of pan under overhang of stair tread, dropping it makes a splashing mess of sludge, bat spreads pan some and lifts tray-- pipe works too
03-11-2019, 05:08 PM | #5 |
Re: Oil Pan baffle
03-11-2019, 06:31 PM | #6 |
Re: Oil Pan baffle
03-11-2019, 06:41 PM | #7 |
Re: Oil Pan baffle
Don't drop it on anything. That's caveman. Do this... It pops right out with a clamp and a piece of wood.
03-11-2019, 07:00 PM | #8 |
Re: Oil Pan baffle
03-11-2019, 07:37 PM | #9 |
Re: Oil Pan baffle
I used a pry bar as I didn’t have a baseball bat and it popped out with a little force but I like the wood and c clamp idea.
03-12-2019, 07:10 PM | #10 |
Re: Oil Pan baffle
This worked like a charm. it took literally 30 seconds to set up and pop the baffle out. Thanks again for posting. The only problem I had was after I took the baffle out and cleaned it up I set it outside the garage. When I put the oil pan back on I had forgotten to put the baffle back in. "Out of sight, out of mind". Its so annoying when ya' do something stupid!! Fortunately I hadn't put the oil in before I noticed it, so it took less than an hour to fix. Something I learned, that most of you probably already know, was to remove the small pipe plug on the side of the block and stick one of the pan bolts in to hold the oil pump in place while installing the pan. If I was going to do this very often I'd make a little tool to screw in the hole that would hold the pump more securely. |
03-12-2019, 08:14 PM | #11 | |
Re: Oil Pan baffle
03-12-2019, 08:29 PM | #12 | |
Re: Oil Pan baffle
I know I might be younger than some on here but that’s how I got mine apart. And believe me it the two parts had been married since the beginning as told by the sludge I cleaned out.
Isaiah B. 1928 all metal Tudor |
03-13-2019, 02:48 PM | #13 | |
Re: Oil Pan baffle
That's exactly what I was thinking of. And you're right; for $6 why try to make one. Thanks for posting that. BTW. I used a bolt that wouldn't actually thread in. It was a smaller diameter but large enough to be stable enough to hold the pump. |
03-13-2019, 02:55 PM | #14 |
Re: Oil Pan baffle
Dipper tray and oil baffle..way more important as a dipper tray,it how your rods get oil
