11-21-2018, 08:00 PM | #1 |
Wiring help needed
I am somewhat versed in wiring but could use some pictorial help. Searching the forums but no luck yet. Installed a flathead in my 32 pickup and when I ordered the harness from Tyree Harris, I got one for a 4 cylinder as that was the plan. I am staying 6 volt and was planning on positive ground as well. I want to install a starter solenoid as but see that there are 2 options, grounded base and one that isn’t. So many questions, which solenoid, how do I connect wiring ? Also keeping the pull start cable that the 4 cylinder had and have sourced a pull switch. Thanks
11-21-2018, 08:16 PM | #2 |
Re: Wiring help needed
Call Tyree. He will be able to help you.
11-21-2018, 08:33 PM | #3 |
Keeping the Model B type pull start cable might be a little tricky in that the starter on the 4 cylinder was mounted on the driver's side of the motor and the V8 starter is mounted on the passenger side. The Model B cable was connected to the switch mounted on top of the starter.
The 4 cylinder starter switch was a "pull type" switch and the V-8 switch is a "push" type switch. It's probably been done...just haven't seen one. Good luck, Pat |
11-21-2018, 08:57 PM | #4 |
Ford used the isolated ground, the start button supplied the ground.
I don't think they used a solenoid until 1937. |
11-21-2018, 09:10 PM | #5 |
Any reason you are going about this in this manner? Seems to be making it more difficult than it needs to be.
11-21-2018, 09:24 PM | #6 |
11-21-2018, 09:37 PM | #7 |
Is this the switch you are looking at? If so, it is rated at 10A on 12v, that is no where near the amperage required if directly connected to the starter. Starters can pull over a hundred amps. It requires a solenoid specifically designed for starter amperage. Are you using this switch to energize a starter solenoid located somewhere else? That would work. If using an early v8 dash mounded starter solenoid all that the switch would have to do is provide a ground.
SKU: 9109 NORMALLY OFF 10A@12VDC 2 SCREWS W/LOCKWASHER USE WITH CABLE OR LEVER MOUNT Last edited by JSeery; 11-21-2018 at 09:55 PM. |
11-21-2018, 09:41 PM | #8 |
but it would supply power to operate a solenoid if that is what he meant?
11-21-2018, 09:43 PM | #9 | |
11-21-2018, 09:57 PM | #10 |
I edited my post in #7. If this switch is used to provide a ground to a dash mounted flathead v8 style starter solenoid, it would work fine.
11-21-2018, 10:17 PM | #11 |
Thanks and appreciate the input and expertise you provide. Just researching more and determined that I need a 6 volt solenoid to handle the current Looks like a Cole Hersee 24097 May be the one I need.
11-22-2018, 08:19 PM | #12 |
That solenoid will work, but will require somewhat screwy wiring. A better option IMO would be an original Ford v8 style and either use a push button switch for the ground or the pull style switch you posted earlier.
11-22-2018, 11:01 PM | #13 |
11-22-2018, 11:13 PM | #14 |
No part number but available from Dennis Carpenter on Ebay-----
https://www.ebay.com/itm/1937-51-FOR...6Ij:rk:34:pf:0
11-23-2018, 12:37 AM | #15 | |
Charlie Stephens |
11-23-2018, 11:43 AM | #16 |
Starter Solenoid 01A-11450 There are different numbers for different years but any will work. The pushbutton on the bottom is handy for trouble shooting. Also, 64-10021
11-23-2018, 12:59 PM | #17 |
11-23-2018, 01:01 PM | #18 |
I am utilizing the cable as it is there and want the modern conveniences of the solenoid. My pickup was an original banger that I have replaced with a 59a and do not have the 32 starter or the mechanism for a floor mounted button.
11-25-2018, 09:19 PM | #19 |
Might as well rewire it also to have a voltage regulator then and eliminate the cutout. 40's on.
I like my stomp starter on my 36. But I'm weird. |
11-25-2018, 09:40 PM | #20 |
With very little effort you could use the floor starter and solenoid. If you choose too. It's just a ground to starter connection. Floor starter and the bash button is just a on/off switch. No more no less. Stomps were just a straight battery 6 to starter. Later dash button just allowed a smaller wire to activate the solenoid to trigger full volts/amps to starter.
Could do the same with the stomp switch vs the button. Depending on your harness, and rerouting a single starter wire. |
