Old 12-14-2017, 02:48 PM   #1
Dweber
Default Any One Seen This Style Dunn Dash Panel Before?
Listed on EBay. Never seen this style before. Is it original?
Dweber is offline   Reply With Quote
Old 12-14-2017, 03:11 PM   #2
slammin
slammin's Avatar
Default Re: Any One Seen This Style Dunn Dash Panel Before?
Looked it up on eBay. No doubt its "rare". If you look at the photos, it shows it has been placed over the stock instrument panel. Since the screws to attach the original to the dash are covered by the "custom" piece, I don't know how you would attach it. The oil pressure and temp gauges are still available new for about $60.00 each and are normally mounted in an aftermarket bracket below the stock panel. $500!!!! You can ask anything. If the ignition switch is an original pop out it might be worth $200.00, if all the gauges work.
slammin is offline   Reply With Quote
Old 12-15-2017, 12:53 AM   #3
Chris Haynes
Chris Haynes's Avatar
Wishing the picture would enlarge when I click on it.
1921 Runabout
1930 Tudor
Early 1930 AA
Old 12-15-2017, 12:55 AM   #4
Licensed to kill
Licensed to kill's Avatar
I went to ebay to see it bigger.
Licensed to kill is offline   Reply With Quote
Old 12-15-2017, 12:56 AM   #5
Charlie Stephens
It would be good to give the EBAY item number so we could see a larger size.
Charlie Stephens
Old 12-15-2017, 12:59 AM   #6
Licensed to kill
https://www.ebay.com/itm/Dunn-Dash-G...RaKtc~&vxp=mtr
Old 12-15-2017, 01:05 AM   #7
Chris Haynes
Looks like a home made piece. Temp gage is junk.
1921 Runabout
1930 Tudor
Early 1930 AA
Old 12-15-2017, 04:58 AM   #8
Mike V. Florida
Mike V. Florida's Avatar
Depends on how you define "original".
Original from the factory, no it is not.
Ford authorized accessory, no it is not.
Original from Dunn, maybe but I have never seen one before this one.
Old 12-15-2017, 08:03 AM   #9
burner31
burner31's Avatar
Does this help?
Keith
Shawnee OK
'31 SW 160-B
Old 12-15-2017, 08:12 AM   #10
BillEbob
BillEbob's Avatar
Originally Posted by burner31 View Post
Does this help?
Burner, thanks for doing your magic! That really helps!
BillEbob is offline   Reply With Quote
Old 12-15-2017, 08:22 AM   #11
Joop
Joop's Avatar
As seen in Those Wonderfull
Joop is offline   Reply With Quote
Old 12-15-2017, 08:27 AM   #12
Ray in La Mesa
I have one just like it in my '28 pickup except there is a decal with "Dunn Manufacturing Co. , Clarinda, Iowa" on it in the lower center of the face. It mounts directly over the A instrument panel, including the dash light. The bottom screws of the A panel are left alone and the upper screws of the A panel go through the Dunn panel & A panel. There are two small straps riveted to the bottom face of the Dunn panel that go back on the outside of the wiring tunnel and mount with sheet metal screws (UGH). On this one, it looks like the bottom screws might hold the straps.
Ray in La Mesa is offline   Reply With Quote
Old 12-15-2017, 09:51 AM   #13
slammin
slammin's Avatar
Good find Joop!
Old 12-15-2017, 10:08 AM   #14
vulture
vulture's Avatar
This is a article in the 1973 issue of the restorer..
Where can I find that Book Joop? I have heard of it but never seen one at the meets
Wanted Roadster Pick up thank you COLOR]
vulture is offline   Reply With Quote
Old 12-15-2017, 10:52 AM   #15
JDupuis
JDupuis's Avatar
Let us know if any Barners buy it.
With the exchange on the Canadian dollar, I can buy another car. I'm out! . Jeff
Let's let pylons, be pylons!
JDupuis is offline   Reply With Quote
Old 12-15-2017, 06:14 PM   #16
CHuDWah
CHuDWah's Avatar
Ended - no bids.
I guess it's OK but the Aristocrat is better looking.
CHuDWah is offline   Reply With Quote
Old 12-15-2017, 06:20 PM   #17
al's28/33
al's28/33's Avatar
that thing is UUUUUGLY, why insult your original dash ?
1928 "A" Phaeton (mid year with many early features)
1933 "V8" Closed-Cab Pickup Truck
(originally a Model B, 4 Cylinder dating to May, 1933)
Old 12-15-2017, 08:17 PM   #18
Joop
Joop's Avatar
Google it
Product details
Author: Murray Fahnestock
Publisher: Post Motor Books
Pages: 250
Format: paperback
ISBN: 0911160272
Old 12-15-2017, 09:46 PM   #19
CT Jack
CT Jack's Avatar
Looks quite junky to me. If you have $500 burning a hole in your pocket send it to the Salvation Army it will be very much appreciated and put to good use.
CT Jack is offline   Reply With Quote
Old 12-15-2017, 10:13 PM   #20
Joop
Joop's Avatar
Now this is a nice one!
