Old 12-18-2017, 06:57 PM   #1
CarlG
CarlG's Avatar
Default Re: Ford 150 OD Transmission install in 31 Roadster
I have the RTS 3+1 27% OD, with 3.78 rear, closed drive line. IMHO, that's the perfect combination.
Alaskan A's
Model A Ford Club of America
Model A Restorers Club
Mullins Owner's Club
Old 12-18-2017, 07:26 PM   #2
JRN1967
JRN1967's Avatar
Carl, I've read that you and many others preferred the 27%. But they are getting harder to find.
Thank you
John
JRN1967 is offline   Reply With Quote
Old 12-18-2017, 07:30 PM   #3
CarlG
CarlG's Avatar
Thank you
John
The guy that I got mine from builds them that way using all new gears regardless of what they were originally.
Alaskan A's
Old 12-18-2017, 09:44 PM   #4
modelAtony
modelAtony's Avatar
Originally Posted by old31 View Post
I am looking to install Ford RTS 150 4 speed trans with a 41% OD.
Car is a 31 Deluxe Roadster with Snyder 5.5 head, enlarged intakes, new motor, B grind cam, FSI Zipper distributor and 4:11 rear end.
I would appreciate it if the people that make the complete 150 kits PM me with your kit info, or reply to this post so others could have the same information.
I have read everything I can from the Barn, Hamb, Mitchell, Volvo, etc.
Check out my site. I run 3:27 and mitchell od on my 31 Tudor
modelAtony is offline   Reply With Quote
Old 12-19-2017, 01:41 PM   #5
Russ/40
Russ/40's Avatar
Ken, thank you much for the clarification. So, the T5 solutions also require torque tube shortening. Is this true with the Clings V8 transmission solution?
Old 12-19-2017, 08:04 PM   #6
JRN1967
JRN1967's Avatar
Ken, After you cut off the tail section of the RTS transmission. How do you
seal the RTS from leaking fluid out of the output shaft? Do you use a sealed
rear bearing? How do you stop fluid from entering the U joint coupling area?
Old 12-19-2017, 08:42 PM   #7
AL in NY
AL in NY's Avatar
JRN1967, if you look at the pictures posted in post #20. You'll see that the tailshaft has been removed and replaced with a flat plate. The rear bearing is replaced with one that is sealed on one side. Also, in regards to your earlier post about the 27% OD trans getting hard to find. Check out this junk yard search site(http://car-part.com/). Depending on how far you want to travel, that transmission is available.
Carlg, David Delume does not replace the internal gears in the F150 transmission with new ones because they are not all available, especially the cluster gear. The cluster gear is unique to each different OD ratio.
AL in NY
AL in NY is offline   Reply With Quote
Old 12-19-2017, 10:12 PM   #8
kenparker
kenparker's Avatar
Al has already answered the questions by Russ, but I can answer also and maybe add some more.
The "flat Plate" Al mentioned is the replacment for the tailhousing. A sealed bearing is put in place of the original open bearing, thus, preventing transmission oil from flowing, leaking or sneaking into the Ujoint cavity. Or Ujoint grease from sneaking into the tranny.
Different Kit builders build their "flat Plate" differently, but all versions work the same purpose.
Every T-5 transmission conversion I have seen has been an open Drive conversion. That is why I do not want to mess with them. Never done a comversion that fits behind the early V-8 transmission, but no reason it could not be built with a shortened drive shaft and Torque Tube.
Remember, if one shortens the Torque Tube the Radias Rods have to be shortened accordingly. ken
kenparker is offline   Reply With Quote
Old 12-20-2017, 03:58 PM   #9
JRN1967
JRN1967's Avatar
Al & Ken, thanks for the answers to my seal question.
Al, I checked out that parts site. Found two within driving distance, I'm saving it to my favorites.
John
Old 12-21-2017, 06:17 PM   #10
bettlesr
bettlesr's Avatar
I got my kit from Tim Sheridan. His kit uses the standard bellhousing and does not cut the cross member. For the space, the top and bottom ears of the universal joint housing are removed, and the brake cross shaft is shimmed lower by 1/4". The drive shaft is cut 4.5".
1965 Lotus Elan S2
1930 Model A Sport Coupe
bettlesr is offline   Reply With Quote
Old 12-24-2017, 10:02 AM   #11
JRN1967
JRN1967's Avatar
bettlesr, This arrangement must put the shifter another 2" further back toward the seat, correct?
Happy Holidays,
John
Old 12-22-2017, 05:35 PM   #12
Chris Haynes
Chris Haynes's Avatar
The 7.50x16 rear tires on mine are all the overdrive I could ask for. :-)
1921 Runabout
1930 Tudor
Early 1930 AA
Old 02-18-2018, 01:18 PM   #13
duke36
For the f150 4 SPEED, what fluid is used and how to drain it? Appears to be no lower drain hole. Does one remove the bottom bolt or use a suction gun?
Old 02-18-2018, 01:45 PM   #14
kenparker
kenparker's Avatar
To duke36. A technical correction for better explanation. The F150 4 speed is just that - a 4 speed. It has an iron case and 4th gear is 1:1. It is a heavy duty transmissioin built for heavy trucks (ie 250 and 350).
The transmission we are (i think) is the F150 RTS 3 speed with OD.
If the transmission is out of the car just turn it upside down and drain then flush.
Now. To answere your question. For 20 years I have been using and recommending whatever is on WalMarts shelf - 80-90 gear oil or 90 wt gear oil or up to 125 wt. Most of the brands come out of the same refinery. 90 wt is what the Ford manual recommends.
There is no drain. The ods of you wearing that gear oil out is none. That is unless your drive into the beach and get salt water in it. he-he.
Old 02-19-2018, 11:39 AM   #15
bettlesr
bettlesr's Avatar
In answer to John (JHN1967) from a while back, sorry for the delay, didn't see your post until today. Yes, the shift lever comes out about 2" closer to the seat. When I welded a Model A shift lever on to the stub sticking out of the transmission I tacked it on and checked the position of the shifter in all gears and then tweaked it until it felt comfortable. The the shift lever was welded solid,
1965 Lotus Elan S2
Old 02-20-2018, 01:50 AM   #16
28
Who’s good for conversion kits? I just picked up an rts 41od so we’ll see how it does with stock everything soon enough. I can fab up what I need but I’m willing to look at kits from guys that have done this regularly as they probably know what the hell they are doing. I already have an AA bell too. Will be going in a 28 fordor.
28 is offline   Reply With Quote
Old 02-20-2018, 11:25 AM   #17
AL in NY
AL in NY's Avatar
There's nobody reliable making the kits now except for Gary Bernard in Texas. His kit uses the standard Model A bell housing and requires the cross member to be badly notched and the brake cross shaft to be modified. Ken Parker used to do the kits and David Delume is not that reliable. In an earlier post I see Tim Sheridan's name in reference to a F150 kit, but don't know anything about him expect what that post said. The hardest part of the install is modifying that RTS transmission. All the mods to the Model A are pretty straight forward(this is from personel experience doing the install and mods myself).
AL in NY
Old 02-21-2018, 07:34 PM   #18
JRN1967
JRN1967's Avatar
Bettlesr, thank you for answering my question.
Old 02-20-2018, 01:20 PM   #19
CarlG
CarlG's Avatar
I have the kit made by Dave Delmue, as do several of the guys in our club. All pretty happy with his kit. First class machine & transmission work.
Alaskan A's
Old 02-20-2018, 02:05 PM   #20
bettlesr
bettlesr's Avatar
I have the kit by Tim Sheridan. It's very good and the cost was quite reasonable.
1965 Lotus Elan S2
