Old 04-04-2017, 02:54 PM   #1
wmws
Default Coil Polarity
I have seen many wiring diagrams of the Model A ignition system but when they show the coil they don't show what wires go to the + and what goes to the -. The black wire is coming from the ammeter and the red to the ignition switch. I currently have the black to the + on the coil and the red to the - on the coil. Is this correct for the proper polarity. I have tried the lead pencil trick but my eyes are not as good as they once were and I'm not sure if I am seeing the flair. Thanks for any help.
wmws is offline   Reply With Quote
Old 04-04-2017, 03:18 PM   #2
zzlegend
zzlegend's Avatar
Default Re: Coil Polarity
I use one of these.
A-12116
Documents
Model A Polarity Tester
Simply place this unit between the distributor cap and the coil wire, and it indicates if you have the wires on your coil properly as well as if you have spark or not. Comes with complete usage instructions, genuine Nu-Rex. U.S.A.
  • Quantity A-12116 $24.95 / ea.
    1928-31
ADD TO CART ADD TO WISHLIST
zzlegend is offline   Reply With Quote
Old 04-04-2017, 03:31 PM   #3
Bob C
If you have a stock positive ground system then the red goes to the +.
Bob
Old 04-04-2017, 03:31 PM   #4
Art Newland
Art Newland's Avatar
The ignition switch heads straight to the points, then ground, so on a positive ground car, the red wire connects to the +.
Art Newland is offline   Reply With Quote
Old 04-04-2017, 03:32 PM   #5
Art Newland
Yep... what Bob C said. 8^)
Old 04-04-2017, 05:52 PM   #6
BILL WILLIAMSON
BILL WILLIAMSON's Avatar
If it runs BETTER with a certain arrangement, THEN YOU GOT IT RIGHT!
Bill W.
"THE ASSISTANT GURU OF STUFF"
Old 04-04-2017, 06:02 PM   #7
JDupuis
JDupuis's Avatar
I have a 6volt coil for my run-in stand. It does not say + or - it has "bat" and "dist" written on it. I think I've got it hooked up right. . Jeff
Let's let pylons, be pylons!
JDupuis is offline   Reply With Quote
Old 04-04-2017, 06:42 PM   #8
Tom Wesenberg
Tom Wesenberg's Avatar
BAT and DIST is a dumb way to mark a coil because who knows what it was original intended for?
Best to just connect it and then check for spark polarity.
If anyone doesn't know about checking for spark polarity, just do a Google search for "coil polarity" and read the one by chicagolandmgclub.
Old 04-04-2017, 07:06 PM   #9
Mitch//pa
Your better off with a coil that is marked +. Or -- So you know exactly how to wire it.
As Tom said one marked dist / batt could be intended for a neg ground system. If thats the case then you would hook up the Batt to the dist and the dist to the Batt for a pos ground car.
I also have the tool ZZ posted
Old 04-04-2017, 07:54 PM   #10
Patrick L.
Patrick L.'s Avatar
Coil polarity should match battery polarity.
Neg ground battery, neg coil to ground/points
Pos ground battery, pos coil to ground/points
Old 04-04-2017, 10:13 PM   #11
Y-Blockhead
Y-Blockhead's Avatar
Patrick L., Good way to remember.
Old 04-05-2017, 11:05 AM   #12
wmws
Thanks for the help. I have it hooked up right now and with the pencil I think I see the flair toward the plugs.
Old 04-05-2017, 11:30 AM   #13
johnbuckley
johnbuckley's Avatar
Smile Re: Coil Polarity
and tell me wmws..... have you noticed any difference of the running of the engine with the polarity switched either way? I certainly haven't noticed any difference on my A with it either way... but if it revved to 4000 or more I guess that could be a different matter
Old 04-05-2017, 11:38 AM   #14
Tom Wesenberg
I drove my Model A for 2 years with the coil wired wrong, and it never made any difference. Only when you need max voltage to fire the plugs you might feel a misfire.
The coil output is the same either way, but when the hot center electrode is negative it fires easier.
Old 04-05-2017, 01:06 PM   #15
Fullraceflathead
Fullraceflathead's Avatar
I have one Model A coil that doesn't have any markings on it.
"If I asked people what they wanted they would have said faster horses."
-Henry Ford
"Primitive technology is not a design flaw"
1928 Ford Model A Roadster Pickup
1930 Gordon Smith Air Compressor
1941 Willy's Pickup
1960 Thunderbird-For Sale
1964 Buick Riviera 2x4 425
1965 Pontiac GTO, 455 Super Duty
2004 Dodge Ram SRT-10, V-10 Viper
1977 Charger Jet Boat,460 Ford,Jacuzzi Jet
Front Engine Nostalgia Dragster,Supercharged 296 "Fullrace Flathead" Ford
Engine Build up on DVD ask
Fullraceflathead is offline   Reply With Quote
Old 04-05-2017, 01:51 PM   #16
Patrick L.
Patrick L.'s Avatar
Yep. You only should notice any difference under extreme conditions. Wrong coil polarity can reduce output by 20-30%.
Old 04-05-2017, 02:31 PM   #17
wmws
No I don't notice any difference in performance but if it is that easy to have it the right way why not have it right.
Old 04-05-2017, 02:50 PM   #18
Patrick L.
Patrick L.'s Avatar
Oh, I agree. I like right.
Old 04-05-2017, 03:32 PM   #19
zzlegend
zzlegend's Avatar
I ran into this and that's exactly why I bought the tool I posted. I don't trust markings on a coil or the little red and yellow dots on tires, but that's another story.
Old 04-05-2017, 03:34 PM   #20
Mitch//pa
Times 2,,, especially the tires.....
