03-19-2017, 08:22 AM | #1 |
160B header gap?
Replacing the header on my 160B. I hope. in both corners the gaps seem large, it looks like an original header with some water damage. the top was replaced a while back by PO. Did Henry do it this way? the entire seam was covered by hidem. thanks,
the gap is 5/16 to 3/8 inch, and for all the Kiwi's and Brits 13mm.
Richard in New Bern. When everything seems to be going against you, remember that the airplane takes off against the wind, not with it” - Henry Ford Last edited by richsfords; 03-19-2017 at 09:10 AM. Reason: add measurment |
03-19-2017, 06:22 PM | #2 |
Re: 160B header gap?
the gap appears about right and gets covered by orig. metal or aluminum (replacement) moulding available from the vendors, not hidem welt.
03-19-2017, 09:58 PM | #3 |
