03-21-2016, 08:57 AM | #1 |
Oil flow chart
I was wondering if anyone has a diagram for the ford 226h flathead oil flow chart,I can not find one.I was hoping to find out if there is a restrictor built in somewhere in the oil canister assembly on this motor ,thanks
03-21-2016, 09:36 AM | #2 |
Re: Oil flow chart
the restrictor is a brass fitting on the input side that the feed tube from the back of the block screws into. has a very small hole, like 1/32 of an inch, to restrict flow....
03-22-2016, 06:07 PM | #3 |
Re: Oil flow chart
I don't seem to have that,My canister has an inlet and outlet to pan,where does restrictor go? My block has 2 holes but no restrictor that I can see,where can I find a picture of this?Thank you
03-22-2016, 06:13 PM | #4 |
Re: Oil flow chart
They can be any of several places, at the outlet on the block is one common location as is the inlet to the filter.
Older Threads: https://www.fordbarn.com/forum/showthread.php?t=24367 http://www.jalopyjournal.com/forum/t...nstall.963956/ Note: Missed the 226h in the OP, this information obviously only applies to the V8! Last edited by JSeery; 05-12-2016 at 05:00 PM. |
03-22-2016, 06:33 PM | #5 |
Re: Oil flow chart
Thanks alot
03-22-2016, 06:34 PM | #6 |
Re: Oil flow chart
03-22-2016, 06:38 PM | #7 |
Re: Oil flow chart
This is what one type of restictor looks like. There are other types.
03-23-2016, 09:05 AM | #8 |
Re: Oil flow chart
The 226H oil canister is a whole different animal. it attaches to the side of the block. The restrictor is built into the bottom of the canister and passes through to the mounting bracket by means of a ball bearing.
03-23-2016, 09:18 AM | #9 | |
Re: Oil flow chart
Suspect that the ball bearing is a check valve to stop drain back from the filter..
05-12-2016, 03:44 PM | #10 |
Re: Oil flow chart
Where can I get info on ball bearring,never seen one
05-12-2016, 03:48 PM | #11 |
Re: Oil flow chart
Ok,so I know one hole is inlet,the other drains to pan,how would this ball bearing be held in place without falling into block where it bolts to?
05-12-2016, 03:57 PM | #12 |
Re: Oil flow chart
Most likely the end of the hole that the bearing sits in is peened to a smaller diameter.
