#81 | |
![]() Quote:
#82 |
Back before I retired, the shop where I worked had from four to twelve mechanics on the pay roll. Most could bolt every thing we had in stock onto a piece of equipment and consider the job done. We always had to have one man that could determine what was wrong and fix that to get the machine back on line. It takes both kinds.
Bruce
Works good Lasts long time |
#83 |
>>>I just looked at 75 grommets of every kind that Mac's sells for all Fords and didn't see any that looked like they'd work for a hole with curved sides like mine.>>>
http://www.amazon.com/Gb-Electrical-...s=conduit+seal Jack E/NJ |
#84 | |
![]() Quote:
I actually won't be needing any grommets because I'm going to use the original style conduits that have fittings on each end to push into the holes in the light bucket and fender. That should set me up for life as far as headlight wiring goes. ![]() The bottom grommet is to be used if the conduit is not used. That's how my right light was set up just with one grommet and rubber coated wire. But, I'm going to use the conduit and fittings on both sides.
Prof. Henry (The Roaming Gnome) ![]() "It is good to have an end to journey toward; but it is the journey that matters, in the end.” *Ursula K. Le Guin in The Left Hand of Darkness Last edited by Old Henry; 05-05-2016 at 09:51 PM. |
