01-08-2015, 03:46 PM | #1 |
Heinze wiper motor wanted
Why would a posting with this title disappear?
Can someone help with this? Thanks, Al |
01-08-2015, 03:48 PM | #2 |
Re: Heinze wiper motor wanted
Likely because it belonged in the swapmeet. Just a guesse. Rod
Do the RIGHT thing - Support the H.A.M.B. Alliance!!!! |
01-08-2015, 04:18 PM | #3 |
Ya,......well I thought it had good information..
01-08-2015, 05:36 PM | #4 |
Yes very good info!
Can't find it the swap section either??? |
01-08-2015, 05:38 PM | #5 |
It says "The Swap Meet" right on the top of this web page toward the right of the middle.
01-08-2015, 05:43 PM | #6 |
Ray White |
01-08-2015, 05:47 PM | #7 |
Here is the link to the Model A Wanted swap page. https://www.fordbarn.com/forum/forumdisplay.php?f=17
01-08-2015, 05:49 PM | #8 |
So what are the gears worth? How much will the market bear for these if a run of ten were made??
01-08-2015, 05:53 PM | #9 | |
Now,.... I can't remember what the other photo(s) looked like. Question;....is that a thru hole? |
01-08-2015, 06:41 PM | #10 |
Yes, this photo shows the thru hole.
Good question, Brent. I don't really know much about volume and demand. But the gear looks easy to reproduce. If the outer teeth get stripped, the gear may be repairable.
Ray White |
01-08-2015, 09:04 PM | #11 |
Brent,
The pinion assembled to my gear is swaged on and I don't know how it would be replaced after removal' The pinion shown in Newshirt's photo appears to be pressed using a spline which may be re-assembled by pressing. This may influence demand of ten or more gears depending on assembly design. Thanks to all for your help, Al |
01-09-2015, 11:27 AM | #12 | |
it with wire EDM is possible. Back to supply and demand... |
