12-01-2023, 04:01 PM | #1 |
Starter Not Working (Just Humming)
Needless Prose
So I've embarked on the great and ambitous journey of getting all of the Mitchell Manufacturing cars up and running again as none of them have been driven for ~10+ years. On the positive they have all been stored indoors and dry. The other rub is that while I'm a very competent grape farmer and a decent computer programer and builder, I haven't spent a lot of time as a mechanic. I'm also trying to get my post count up so I can feel as cool as the rest of you.. So Car One is the 1929 Coupe.. Doesn't have a name apparently.. the other cars do.. I'll probably name this after my Grandma Sue, though I think I'll spare everyone the explination on why. Actual Post Content I'm working on getting the 1929 Coupe running. I've changed all fluids, put in a new charged battery, and gave the tires a good refill... Next goal was let see if she starts. When the starter button is pressed all I get is a hum. So I took a look around the car to se potential culprits. 1. The little fuse on the top of the starter has broken arms on the fuse holder. The fuse is making good contact and we are getting the hum, but it might be restricting the flow enough to prevent turning over 2. Some how the Ametere is falling out. Maybe it's grouding itself out on the frame or something causing insuffcient voltage. 3. Still looking for my dad's multi meter to do more investigation..... I think the most likely is the starter is bunked up from sitting for ten years, but was looking for thoughts or ideas... I already whacked it with a hammer.. didn't work but felt great. Thanks in Advance Blair Mitchell
Check us out at https://mitchelloverdrives.com/ Direct to Contact Form https://mitchelloverdrives.com/contact/ |
12-01-2023, 04:26 PM | #2 |
Re: Starter Not Working (Just Humming)
Blair, the fuse on the starter should not have anything to do with the starter turning over. That fuse is there to protect the rest of the car's wiring.
Sounds like your Bendix may be jammed into the flywheel. There are numerous threads on this issue on Ford Barn. It is a common problem with the original type starter drive. |
12-01-2023, 04:53 PM | #3 |
With the car in third gear, rock the car forwards and backwards as best as possible. If you get a loud clunk, the starter Bendix has loosened itself and the starter should work again as normal.
12-01-2023, 06:43 PM | #4 | |
www.whidbeymodelaclub.com |
12-01-2023, 06:49 PM | #5 |
The engine isn't locked up from setting so long is it?
12-01-2023, 07:14 PM | #6 |
12-01-2023, 07:54 PM | #7 |
Most likely the engine is jammed as others have suggested. My advice is to take the starter out and turn it over by hand. Take the band off and make sure the brushes are moving up and down in their guides. Sometimes the brushes can be stuck and not contacting the armature. Test the starter on the bench with a battery. The polarity does not matter. Use a jumper cable. Take the starter switch off. Clamp one end on an ear of the starter and contact the button where the starter switch normally makes contact. If OK, oil the bearings and put it back in the car.
12-01-2023, 08:19 PM | #8 |
I would suggest removing the 'plugs and adding some type of penetrant and let it soak!!
12-01-2023, 09:18 PM | #9 |
If the Bendix gear is stuck and you try to roll the car a few inches forward and back in gear to un-stick it, the best advice I can give you is: release the handbrake before attempting it five or six times. Ask me how I know.
David in San Antonio 1930 ('31?) Deluxe "Wretched Roadster" Restored 1957 Alamo A’s Club Last edited by David in San Antonio; 12-01-2023 at 09:19 PM. Reason: Edited for hopelessly incompetent typing. |
12-01-2023, 10:45 PM | #10 |
Had a starter motor once that was sitting for who knows how long that the bendex was all gummed up and would not let the gear portion spin down the spiral shaft to engage the flywheel. The starter motor just hummed along spinning. Remove the starter and a few drops of oil on the Bendix shaft to free things up and and get them working might help
12-02-2023, 06:30 AM | #11 |
If the Bendix is locked on the flywheel, the starter will be almost impossible to remove. Try the rocking motion backwards with the transmission in high gear. It could also be that the bolt on the bendix is broken leaving the starter to run and not engage the flywheel.
12-02-2023, 09:37 AM | #12 |
Also, be sure the key is off. Don’t ask how I know that.
JayJay San Francisco Bay Area ------------------------ 1930 Murray Town Sedan 1931 Briggs S/W Town Sedan |
12-02-2023, 09:50 AM | #13 |
Good point.
12-02-2023, 10:20 AM | #14 |
Thank you everyone for all the advice. I'm gonna give all of it a try this weekend as soon as the xmas lights are up and the other list of parent tasks is complete.. (something about a roof on a pump house).
My Summary of Order of Operations to try with quick starter checks in between. I probably missed something, but I'm sure I'll re read later Troubleshooting Plan
12-02-2023, 02:08 PM | #15 |
The poster says the starter hums. If the Bendix drive were locked against the ring gear, you'd hear nothing. Not even a clunk. I suspect that a Bendix gear bolt has sheared off, allowing the starter shaft to spin = a humming sound. Put your palm on the side of the starter and depress the starter rod. If you hear and feel a hum, that tells you the Bendix drive is not engaging, either because of a sheared bolt or a broken spring, although the latter would also produce a clunking sound as the drive spun and the broken spring clattered. In any case, it would be best to remove the starter and examine the Bendix drive and spring. A broken Bendix bolt will be obvious.
Marshall |
12-02-2023, 04:19 PM | #16 |
I thought exactly the same, Marshall. If the engine is seized, the OP might hear the Bendix engage the flywheel but then, nothing - no humming sound. IMO, a broken or missing Bendix bolt is about the only likely culprit.
I'm part of the only ever generation with an analogue childhood and a digital adulthood. Last edited by Synchro909; 12-02-2023 at 06:59 PM. |
12-02-2023, 06:39 PM | #17 | |
Exactly! I saw all the posts talking about jammed Bendix, but if it is humming that tells me that the starter armature is turning. If it were jammed, it would not. It should be able to be removed easily. However, if there are bits of a bolt and washers down in the flywheel housing, you will need to fish them out with a magnet on a flexible thingie to gt the bits out. |
12-03-2023, 11:11 AM | #18 |
Hey Everyone,
Again all the thank you for the advice. I dropped the starter yesterday and took it apart and inspected it, well actually did that twice because I hadn't had all my coffee..
So I'm gonna try that and see if I can get it to move properly. I think we have an extra Bendix around the shop anyways so I might end up just replacing the whole. Thanks and I'll keep updating and likely post pictures. This old car will run again and will take me wine tasting. I'm still trying to decide what friend gets put in the rumble seat after a big lunch.
12-03-2023, 12:26 PM | #19 |
try and keep the solvent out of the motor section as best as you can, and a very light oil works best. your favorite peneratrating oil should get it working good.
12-03-2023, 12:39 PM | #20 | |
Thread Tools | |
Display Modes | |
