09-15-2022, 07:26 PM | #1 |
Backfiring
Hey guys, question here about my car backfiring.. I haven’t driven my A too much since owning it and my timing gear went. I replaced that and did a bunch of other things. Now it’s running and I’ve driven it twice since my repairs and it’s backfiring, mostly on downshifts but sometimes during acceleration as well. It seems like it’s happening in the engine bay and not out the tail pipe. It sounds like it has an exhaust leak so I believe my manifolds need to be machined and new gaskets probably? If my manifolds are leaking this could cause the car to backfire right? Im mainly concerned because I was told that backfiring could have caused my timing gear to fail prematurely? I want to drive my car now that it’s back together and running, but I definitely don’t want to be doing another timing gear. I plan on addressing this manifold issue over the winter but I’d really like to drive it for a few weeks before putting it away for the winter, then I’ll take more stuff apart and address more issues. Do you guys think any harm is being done to the timing gear with the car back firing every now and then? And could there be another reason for the odd backfire other then the manifolds leaking?
Thanks Fordbarn |
09-15-2022, 07:57 PM | #2 |
Re: Backfiring
Speaking from my own experience, my car had some fuel flow problems and would sometime starve for fuel which would cause it to backfire due to intermittent fuel flow while driving above 30 mph. Once I cleared the blockage and got the fuel flowing good again the backfire went away and the car ran normally. Backfiring can also be due to a failing condenser, broken wire under the point plate, etc. If your timing gear is new, I'd begin to check the items mentioned above along with checking your timing to be sure nothing has changed there
09-16-2022, 05:22 AM | #3 |
Re: Backfiring
Backfire can be cause by lack of fuel. check the entire fuel run from inside the tank to the carburetor, and then inside the carb at the filter and the float.
I had that happen because an extra gasket was stuck inside the small glass bowl filter. If you get too many big backfires then your muffler will split open at the top where the seems are, and then you will get perpetual backfires. I had to replace my muffler because of backfires, but that turned out to be a good thing in the end. If you are backfiring when coating down hill check your timing, you may be way advanced. But really look for a leak in the exhaust. With the car running put you hand just above the muffler (if you have a heat shield along side the space), do you feel exhaust air? Replace the muffler. These all happened to me. |
09-16-2022, 07:31 AM | #4 |
Re: Backfiring
I also had backfiring on deceleration and found that 1 full turn CCW on the GAV fixed it, runs in all other modes well. Forgot - does in or out lean or enrich? Does 1 full turn out sound correct? Or, do I have a jet issue?
09-16-2022, 08:25 AM | #5 | ||
Re: Backfiring
I did notice backfiring when Im off the gas and coasting down a hill, it could definitely be that my timing is too advance during this time. I will pay attention to where my lever is next time Im doing this. Thank you CCW will enrich the mixture (add more fuel) I have my GAV almost a half turn out. I havent messed with it while Im driving, but while the cars idling if I turn it either way it starts to run funky and doesnt like it. Atleast at idle I think Ive found the sweet spot, although everyone says each Model A prefers a different GAV adjustment. |
09-16-2022, 10:37 AM | #6 |
Re: Backfiring
Backfire out of the carburetor, ... Your timing is off. Backfire out of the tail pipe, ... Your fuel mixture is to lean. The other .9% is your wire periodically shorting out inside the armored ignition cable. Regards Bill |
09-16-2022, 10:41 AM | #7 |
Re: Backfiring
In addition to what the guys have suggested so far, check the exhaust manifold-to-muffler clamp orientation, specifically the gap between the two clamp halves. If the manifold and muffler pipe are not 100% sealed at this juncture, exhaust can blow past and be sucked into the carburetor's throat. That will cause popping and backfiring, especially during deceleration. Loosen the clamp nuts and rotate the clamp so that the gap between halves is not directly facing the carb's throat. This is an overlooked cause of popping/backfiring that is hard to diagnose unless there are big, black ugly splotches of exhaust soot near this juncture. This is not always the case with leakage in this area.
Marshall Last edited by Marshall V. Daut; 09-16-2022 at 11:55 AM. |
09-16-2022, 12:07 PM | #8 |
Re: Backfiring
Your inline fuel filter could very well be the cause of your problem. If you have had your tank cleaned and have installed a pencil filter in the top of your fuel shut off valve then you should be good.
Model A's are not necessarily fond of the inline fuel filters.
Dave / Lincoln Nebraska |
09-16-2022, 01:32 PM | #9 | |||
Re: Backfiring
Interesting, thanks Ill look into this. Ill play with the GAV next time Im driving. Also, my ignition cable was electrical taped into the distributor from the previous owner. Sounds like this could be a problem aswell. Quote:
09-16-2022, 01:43 PM | #10 |
Re: Backfiring
Back fire is through the carburetor during a lean mixture situation. There is a flow problem somewhere. It could be on the supply side or internal to the carburetor.
After fire is the combustion in the tail pipe or muffler. Sticky or burned exhaust valves are the common cause of that. |
09-16-2022, 01:56 PM | #11 |
Re: Backfiring
With a rusty fuel supply I would reflush the tank, put a magnet in the glass sentiment bowl. Fix the exhaust leak, and clean the carb.
Do one thing at a time. |
09-16-2022, 01:56 PM | #12 | |
Re: Backfiring
IMHO, 1 full turn CCW on the GAV is too much. Here's some ideas, check for air leaks at the throttle plate shaft, the carb to manifold, manifold to block, wiper connection, set your base idle rpm / Idle Air Adjustment Valve, clean the carb passages.
"It ain't what you know for certain that gets ya in trouble. It's what ya know for certain that just ain't so!" Last edited by Rob Doe; 09-17-2022 at 04:35 AM. |
09-16-2022, 02:06 PM | #13 |
Re: Backfiring
Back fire through the exhaust is sometimes called after fire and is often a rich mixture allowing raw fuel to make it into the exhaust. This happens sometimes as the car is turned off and, if I remember correctly, when you let off the gas to coast.
That said, an exhaust leak can make popping sounds too as Mr. Daut has said. I learned from his post about the exhaust contaminating the intake air horn of the carb. On radial aircraft engines, exhaust leaks can make popping sounds due to rapid expansion / contraction of air moving in or out of the exhaust leak itself. (So I was taught)
"It ain't what you know for certain that gets ya in trouble. It's what ya know for certain that just ain't so!" Last edited by Rob Doe; 09-16-2022 at 02:39 PM. |
09-16-2022, 04:02 PM | #14 |
Re: Backfiring
Just remove the inline filter for a short period to see if the issue resolves. If it does you've found the problem. If it doesn't put it back on.
09-16-2022, 04:28 PM | #15 |
Re: Backfiring
09-16-2022, 06:02 PM | #16 |
Re: Backfiring
You should have a good flow at the carburetor inlet fitting with the line disconnected and the fuel valve on. If you don't them it's on the supply side. If flow is good then it's in the carburetor. Crud can block the float valve or the jets but something is getting low flow.
09-16-2022, 06:06 PM | #17 | |
Re: Backfiring
With the fuel line off the carb and gas valve turned on gas is flying out of there pretty quickly. I’d say there is sufficient fuel flow. So I guess maybe I’ll take the carb off and give it a good clean again. I’m getting really good at taking this carb apart.. |
09-16-2022, 07:51 PM | #18 |
Re: Backfiring
I had backfiring and sputter. Turned out to be the condenser. I could not keep condensers installed for more than 50 miles until I had to change it for backfiring issues. I went to the modern upper and lower plate design in the distributor and I never had any problems since. Improved the reliability of the car immensely.....no issues.
09-16-2022, 08:04 PM | #19 |
Re: Backfiring
I notice nobody has asked whether you’re using a Zenith carb, a Tillotson carb, a Marvel carb. The Tillotsons and Marvels, being pot metal, have a tendency toward at the mounting flange, causing vacuum leaks, which will definitely have an effect on overall running.
And, while having the GAV adjustment at the choke rod open a full turn is usually way too much for a Zenith, 1/2 to 3/4 turn open for Tillotsons is not that strange. |
09-17-2022, 04:31 AM | #20 | |
Re: Backfiring
Thread Tools | |
Display Modes | |
