08-30-2021, 09:50 PM | #1 |
Two tooth steering column
Anyone have any input on cotton picker 00 in the steering box? I have fresh new rebuilt two tooth column and have a very slow drip. It has been gone through three times with all new gaskets and seals and continues to have a slow drip. Someone said Cotton Picker 00 was a good solution compared to 600 weight oil?
Thoughts before I add to the fresh gear box? |
08-30-2021, 09:57 PM | #2 |
Re: Two tooth steering column
Have you installed one of these?
STEERING HOUSING END PLATE WITH TUBE A-3568-T 29-31 For the 2-tooth steering gear assemblies. This tube replaces the end plate on the steering column and has a tube that goes up above the oil level to prevent oil leaking. The tube is welded to the end plate. U.S.A. Quantity: $9.50 EA Snyders and Brattons at least both carry them.
08-31-2021, 07:13 PM | #3 | |
08-31-2021, 07:27 PM | #4 |
Cornhead 00 is a thixtropic, self leveling grease. I have it in my u joint, but I use steering grease from California restorations in my steering box. It is a self leveling grease as well. I don’t have to add oil every couple of weeks.
08-31-2021, 08:56 PM | #5 |
I use John Deer cornhead grease works for me usually will not run out
08-31-2021, 11:11 PM | #6 |
Thread Tools | |
Display Modes | |
