04-24-2020, 09:10 AM | #1 |
Sick Feeling
I have this heavy sick feeling in the bottom of my stomach. Got my rebuild 276 ready to fire up for first time and could not get oil pressure when turning it over with starter. Dropped the oil pan and removed the oil pump and the gasket for the oil pickup was suspect, put back together and had oil pressure.
Could not get fuel pump to prime so removed and had one of the valves turned wrong way. changed direction and had gas shooting out fuel pump. Engine started easy 45 lbs oil pressure and was idling fine and gasket on oil filter housing lid was leaking; oil everywhere took 3 tries to get sealed. Started the engine and let warm up to 180 degrees no issues smooth running. Cut off and let set overnight and then retorqued head bolts next day. Started up fine and then oil pressure line had a defect from factory and sprayed oil all over the engine and shop. Repaired that and now I'm ready to restart. Started the engine and let warm up started checking the timing and move the distributor to far and engine died. Hit the switch again and started made awful sound (used starter) as engine started. Took starter off and bearing and parts from starter where inside transmission (AOD) got all the metal out I could find with magnet and bought a new starter. Started the engine yesterday evening and something definitely has broke inside the engine. Got that sick feeling it is major. Going to walk away for couple of days before dropping oil pan to see what is. |
04-24-2020, 09:24 AM | #2 |
Re: Sick Feeling
Certainly odd to an ominous start. Got to ask, did you build it?
04-24-2020, 09:27 AM | #3 |
Re: Sick Feeling
Wow! The bad luck gremlins are working overtime.
Getting Rid of Bad Luck. Use salt. Salt is considered good luck by many cultures in the world. In order to get rid of many forms of bad luck you can take a pinch of salt and throw it over your LEFT shoulder (throwing salt over your right shoulder will bring you more bad luck). I know it doesn't seem so but, things will improve. Hang in there. |
04-24-2020, 09:29 AM | #4 |
Re: Sick Feeling
Oh, man. Sorry to hear that. You've certainly had your share of struggles with this motor. Hopefully it's something small. Please report back what you find when you drop the pan.
04-24-2020, 09:50 AM | #5 |
Re: Sick Feeling
Yes, Flatjack9 I built the motor, not my first build, but definitely different than other engines.
04-24-2020, 12:24 PM | #6 |
Re: Sick Feeling
04-24-2020, 01:00 PM | #7 |
Re: Sick Feeling
Do you have an access hole in the bottom of the AOD bellhousing? One rebuild tip is to drill an access hole (with a hole saw), it gives you a bit of room to fish things out of there.
Before you start taking things apart, might pull the plugs and do a compression test. Might let you know if something major is wrong inside. |
04-24-2020, 01:02 PM | #8 |
Re: Sick Feeling
Oh man, I feel for you.
This is why I always run on a stand before installation. |
04-24-2020, 01:10 PM | #9 |
Re: Sick Feeling
Please describe the noise it made. Is it possible that there is still something inside the flywheel housing, like the Bendix spring, that the flywheel is batting around?
04-24-2020, 03:25 PM | #10 |
Re: Sick Feeling
Best way to describe the noise is metal sound bamb, bamb, bamb. I will take the plugs out and check them and put the compression gauge on the rear two cylinders. Sound definitely at the very back of the engine or front of transmission.
04-24-2020, 03:43 PM | #11 |
Re: Sick Feeling
I left a torque converter bolt loose once in my Pontiac and it made a banging noise as you’ve described.
Al |
04-24-2020, 04:43 PM | #12 |
Re: Sick Feeling
Wow I feel sorry for you reminds, me of Hee Haw, if it weren't for bad luck I'd had no luck at all.
04-24-2020, 06:26 PM | #13 |
Re: Sick Feeling
I'm not superstitious and I don't read horoscope/astrograph. As the right reverend Ray J. would say "it is just a season".
04-24-2020, 06:40 PM | #14 |
Re: Sick Feeling
Do they use a flex plate ? If so a cracked flex plate will sound like a rod knock or worse a couple of rods .
Good luck , hope it's small . |
04-25-2020, 10:03 AM | #15 |
Re: Sick Feeling
One of the AOD kits I've looked at uses a conventional starter to turn the flex plate. They have aluminum housing parts that won't stick to a magnet. You need to check out that converter if you can. Did you get enough pieces out of that area to be able to piece the starter back together?
Everyone has bad days. I've had my share. I usually call it an early day on those and find something else to do. |
04-25-2020, 01:45 PM | #16 | |
Re: Sick Feeling
To the O/P : Hopefully it will be something minior; I think there's a pretty good chance of that from what I've read. |
04-25-2020, 09:04 PM | #17 |
Re: Sick Feeling
I got to test 5 cylinders tonight before it got dark and had compression. Tomorrow after lunch is the day I take a look at everything more closely. After turning the engine over for the compression test I got a slight smell of electrical. The new battery cables were warm and starter also. Something is putting a drag on everything.
04-26-2020, 01:43 PM | #18 |
Re: Sick Feeling
Tested all the cylinders and have compression. Looked in through the spark plug hole and I have one cylinder #6 getting some antifreeze in cylinder. Dropped the oil and filtered through coffee filter and found nothing. Removed the starter and turned the flex plate 360 degrees and all nuts for torque converter on tight and did not see any cracks or anything rubbing.
Decided to put back to together and see if sound was still there. It is, but sounds like a metal fan blade hitting metal shroud. Noise is louder at low rpm's and after engine gets going sound almost goes away. I have oil pressure and engine cranks easily. I purchased the early 70's starter that the kit said use (short gear) with the front cover part that came with the kit. Could the starter be part of the problem I could not distinguish where the sound is coming from. |
04-26-2020, 02:28 PM | #19 |
Re: Sick Feeling
Here's some random information about strange engine noises. I had one in my '51 Ford I couldn't track down. I tried everything and couldn't find it. I initially thought it was a throwout bearing, because it went away when I depressed the clutch. I pulled the engine and replaced it with a Mercury I had. I had to swap oil pans, and when I cleaned out the Ford pan, I found a chunk of the thrust surface of the rear main in the bottom of the pan. It was about an inch long. I initially didn't know what it was, but when I compared it to a new rear main bearing I had, it was dimensionally the same. I don't know if it was the actual cause of the noise, but I am going to replace the rear main on the Ford engine and see. (The engine was in good shape otherwise.)
04-26-2020, 02:39 PM | #20 |
Re: Sick Feeling
Years ago, I had a Maverick come in. The owner had been given an estimate of 300 bucks to replace the main bearings. I had him on the road in fifteen minutes all fixed by tightening his converter nuts.
Thread Tools | |
Display Modes | |
