#1 |
I have my 1929 Coupe transmission and bell housing out of the car and am trying to re-install the U-Joint. Should the U-Joint slip easily onto the splined shaft of the transmission? Mine didn't want to slip on, so I tapped it gently with a hammer and it just got stuck and I had to tap it off with a long screwdriver.
I had assumed that it would just slide on without fuss and then I could attach the retainer and bolt through the back part of the U-Joint with a socket on an extension. Any ideas? My old U-joint is not worn or anything, I just want to get my car back together. I plan to put the transmission and bell housing in and support it while attached to the torque tube and re-install the engine. I removed and replaced my engine once this way when I lived in Alaska. |
#2 |
It should slide in there NO problem. I recently did a major overhaul and bought a new universal joint. I had the same problem...it would NOT go on. I returned it to the vendor. I ended up rebuilding my original and it worked perfect. It sounds like you are using your original but DON'T force it on. Check to see if there are any burrs on the spline or the U/J. If so carefully remove them with a small file and make sure you clean out all the filings with spray cleaner before reassemble. Hopes this helps.
#3 | |
![]() Quote:
Installed fine and has been working great ever since. |
#4 |
Did you have trouble getting the joint off ? It should go on fairly easily. Just look to see that the splines didn't get buggered [ technical term] up and take a file to them if they did. A little oil may help. It should fit pretty tight, but, it should go on easy if lined up right.
#5 |
I don't remember having any difficulty removing the U-Joint 5+ years ago, but knocking the transmission/bell housing around the garage for five years may have buggered up something a bit. I will tackle the close inspection on Monday when I have my day free. Thanks for the help, guys.
#6 |
#7 |
We all go through it. But the reward is well worth it when you take her for a drive!! I just wrestled with a generator gone bad. Partly my fault coupled with sitting for years before I got it. But all's well that ends well!
#8 |
Good. Nice to hear its back together, almost. Yep, there is a lot to learn about these old monsters.
Thread Tools | |
Display Modes | |
