12-15-2017, 09:05 AM | #1 |
Sticky cut out
Is there a fix for a sticky cut out? About 1/2 the time the points will stick closed on my "new" cut out. If I thump the cover with your knuckle then they will open. Kind of a pain having to check it every time I shut the car off.
12-15-2017, 09:13 AM | #2 |
Re: Sticky cut out
install a diode and be done with it. Original cutouts can still be found that work.
1929 Model AA - Need long splash aprons! |
12-15-2017, 09:43 AM | #3 |
Re: Sticky cut out
My generator has the newer electronic cutout and works great. No more crappy, unreliable service from those cheap cutouts.
12-15-2017, 09:44 AM | #4 |
Re: Sticky cut out
A cleaning and adjusting of an original should correct that problem. The originals work well.
12-15-2017, 02:15 PM | #5 |
Re: Sticky cut out
I've installed the low cost diodes from Brattons and Snyders . The diodes are less than ten dollars and work well . For me the Snyders diode installs easier in the old repro cutouts . Brattons diode installs easist in the original cutouts. Both have easy to follow instructions. It is necessary to gut the cut out . I use rosin core solder and an electric soldering gun . Rosin core solder doesn't run off like acid core solder and doesn't require flux . Surfaces must be clean !!! A much better choice is the Fun Projects can style voltage regulator,It acts like a modern regulator and there is no points to stick Try www.funprojects.com
12-15-2017, 06:48 PM | #6 |
Re: Sticky cut out
Ron |
12-15-2017, 07:45 PM | #7 |
Re: Sticky cut out
For sticking originals, increasing the air gap, slightly & increasing the spring pressure, slightly, will help. "Sometimes" the sticking is caused by RESIDUAL MAGNETISM & those adjustments help them "break" apart.
When I worked on Volvos, this was a common problem with Bosch Relays. They make GREAT "special" purpose relays, as each different type, has the CIRCUITRY, embossed on the cover. Bill Click
"THE ASSISTANT GURU OF STUFF" Last edited by BILL WILLIAMSON; 12-16-2017 at 10:29 AM. |
Thread Tools | |
Display Modes | |
