07-02-2016, 09:40 AM | #1 |
Model b zenith float spring
Does anyone have a picture or instructions on how to install the float assist spring on the number two style zenith model b carb? I am running a fuel pump on my speedster with duel model bs . The fuel pressure is set at two pounds. The carbs have started to drip gas out the over flow. The b carb have the rectangle (number two style) float with surge baffle. I have the book " The Rex Rehirs Way " . It shows a picture of the float and surge baffle , but not the spring installed . Any input would be helpful. Thanks Miff
07-02-2016, 11:48 AM | #2 |
Re: Model b zenith float spring
Go to Vince Falters Ford Garage, he has some assembly pictures for the B carb, it shows the spring in a side view, it will help.
Nothing can be made foolproof, ---- fools are ingenious bastards. |
07-02-2016, 03:05 PM | #3 |
Brian T I went to the ford garage web page . I saw the parts lay out on the b two carb . What I need is a picture of the spring installed . I guess it's to putting the spring in . It can only go in two ways .thanks
07-02-2016, 08:04 PM | #4 |
If you have the spring it should be easy to figure out, I found this hand drawn picture, person unknown, maybe this will help.
07-02-2016, 08:17 PM | #5 |
Thanks I figured it out. the hook side of the spring fits around the float post.The straight side of the spring goes between the float and the baffel . Putting light pressure on the float that pushes on the shut off . Thanks for the follow up . Miff
04-03-2023, 09:19 PM | #6 |
04-04-2023, 07:33 PM | #7 | |
I.e. If left in place on the Model A it causes the float valve to "close" and not admit fuel to the bowl. Joe K
Shudda kept the horse. Last edited by Joe K; 04-04-2023 at 07:41 PM. |
04-05-2023, 06:13 PM | #8 |
Renners, I have heard that too. My (gravity fed) B carb does not have the slosh baffle either.
Thread Tools | |
Display Modes | |
