07-11-2022, 01:22 PM | #1 |
Rebuilding OEM shocks
Currently I have been rebuilding some OEM shocks.
The Robert Paul shocks I hoarded for a dozen years are gone to authentic restorations. I found a set of rebuilt shock cores that were bushed, and machined, and Babbitt used to resurface the rotor. Heat melted some of the Babbitt when I took them apart. Possibly Apple Rebuilds? One of those cores is an unusual base casting, several rings cast in the underside of the base, so not OEM. I rebuilt a set of originals for my son that went thru a shop fire. They are fine. Just like opening a box of chocolates, I only learn how good the core is when I get it apart, and cleaned up. There are 4 makers, some 23 changes, and CW, and AC, so coming up with complete sets is problematic. Several club members have rebuilt sets years ago and recall the effort it takes. Probably takes half a day to get one apart to see if it is usable. One day total to Finish. |
07-11-2022, 01:57 PM | #2 |
Re: Rebuilding OEM shocks
Yep, I built dozens, maybe a hundred, 15+ years ago. No only is it tough, it’s nasty dirty and stinky when cooking or torching.
Cooking in charcoal is about necessary. You’re correct about time required. THEN, I was finding maybe 1 in 8-10 being rebuildable. I had already culled the “usual suspects” of…off center, open and pour our rust…. Investing the time and effort in those not good and you’ve got a lot of sweat equity in the few good ones. I have lots of good shocks that I put away but no longer attempt opening up additional cores… Done |
07-11-2022, 02:48 PM | #3 |
What do we think about the Apple rebuilds? I think they're still offering them.
07-11-2022, 10:51 PM | #4 |
My opinion:Apple shocks are probably
Lifetime shocks, if you have, or locate good cores. The set I rebuilt were not correct, with The one ringer, and were damaged opening them up with heat, as I mentioned, so to repair them they would probably need to go back to the rebuilder to be redone. This set still needs to be assembled to check the function. Last edited by Brentwood Bob; 07-11-2022 at 10:59 PM. |
07-12-2022, 05:47 AM | #5 |
BB..
Not quite sure what you mean.. “Lifetime shocks”? Sealed? If you opened apple shocks how did you know they were theirs? I thought they restored original shocks. Identify markings? |
07-12-2022, 10:12 AM | #6 |
07-12-2022, 12:33 PM | #7 |
My lifetime.
Swag on being Apple shocks, the effort impressed this guy. 3 of the 4 I bought as cores had similiar bases, all 4 had same covers, all were intact. They all came out of the same discard pile, so I assume they were a set. Being "possible Apple shocks" seems like a good guess. The guts, other than the rotor, were machined, and upgraded/ replaced. Who else would do that? |
07-13-2022, 08:45 AM | #8 |
I'm pretty happy with my Apple rebuilds. I didn't think two out of four were going to be rebuildable. And I know, I have to get tubular links. There seems to be a shortage right now.
07-14-2022, 10:33 AM | #9 |
Be cautious of Apple rebuilds. Test them in a vice before installing through the adjustment ranges for hopefully consistent motion. Also, check what fluid they fill them with ?
07-14-2022, 12:29 PM | #10 |
Tha Shock with CAS is Canadian. Nice looking set on the car.
A 50/50 rebuild would probably work fine unless you are sensitive. Robert Paul's advice was to leave his adjustment alone unless you live in an extreme climate, even then don't wear out the needle valve with seasonal adjustments. I value the OEM set, as specified in the judging standards, for the same money. Even a mixed set from different manufacturers over tubular, or mechanicals. |
07-14-2022, 09:18 PM | #11 |
Just got the new volume 10, How to Restore Your Model A, from MAFCA.
Excellent article by Steve Schmauch describing the Houdaille Shocks. |
07-14-2022, 09:22 PM | #12 |
Had no idea that was a Canadian shock. The mixed set I had bothered me at first but I got over it. I really don’t plan on making any seasonal adjustments. Vast improvement over non-existent shocks so I’m happy.
07-14-2022, 11:40 PM | #13 |
What oil does Apple use? Core charge? Guarantee?
07-15-2022, 10:49 AM | #14 |
Here's their page:
https://www.applehydraulicsonline.co...ur-ford-shocks |
07-15-2022, 12:05 PM | #15 |
Could not access the files.
08-17-2022, 09:51 AM | #16 |
couldn't also
08-18-2022, 10:51 AM | #17 |
In there Q&A section they state not to open them for the first 5-years. If servicing, they recommend SAE 10 to 20 jack oil or equivalent motorcycle fork oil.
08-18-2022, 11:18 AM | #18 |
I used 85-140 wt gear oil when I rebuilt the 4 I think were Apple rebuilds.
08-18-2022, 11:35 AM | #19 |
Hello, I know they recommend jack hydraulic oil for the GM type “knee action “ shocks, have a set on 49 Buick,made a big difference in ride , they are coil springs all around on it.Apple been around since probably the 1970,s I think.
09-26-2022, 01:20 PM | #20 |
I have several sets that are ready to install. See the for sale section. 1929 thru early 1931 build date sets.
09-26-2022, 01:31 PM | #21 |
Here is what I did:
Core is disassembled, cleaned, inspected, new seals and stem packing installed, inner cover fitted, refilled with 85-140 gear oil, reassembled, resealed cover and stem valve, tested for function, adjusted, then painted. Then sorted to match a correct set of original functioning shocks, ROAD READY. |
10-29-2022, 08:06 PM | #22 |
Here are some pictures of me rebuilding a shock start to finish
10-29-2022, 08:07 PM | #23 |
Very rusty cores at the beginning time to clean them and rebuild them
10-29-2022, 08:10 PM | #24 |
After a good cleaning. They look much better now and all the channels and valves are cleaned and working good
10-29-2022, 08:13 PM | #25 |
Thread sealer,installing 2 o rings, filling with gear oil. Adjusting the shocks
10-29-2022, 08:15 PM | #26 |
06-05-2023, 10:13 PM | #27 |
More shock covers
06-05-2023, 10:15 PM | #28 |
Nice cover I cleaned up
06-05-2023, 10:20 PM | #29 |
Clean internal shaft
06-05-2023, 10:21 PM | #30 |
Several shocks I am working on. I am putting together a correct set of late 1931 shocks
06-05-2023, 10:23 PM | #31 |
On work work bench are some single shocks I have rebuilt
06-05-2023, 10:24 PM | #32 |
Finished set of 4 shocks. If you need any let me know
Thread Tools | |
Display Modes | |
