04-24-2020, 04:29 PM | #1 |
62 TBird Master Cylinder
Swapping to disc brakes on the bird. Having issues with the MC that came in the kit - way too big. Was curious what other options there are out there for MCs that would work? Doesn’t need to me stock looking.
1931 Model A Victoria 1950 Mercury 8 Member: MAFCA, MARC, Northern Ohio Model A Club www.northernohiomodela.com |
04-24-2020, 04:37 PM | #2 |
Re: 62 TBird Master Cylinder
What kit did you buy and what exactly is wrong?
- WANNA SEE A GOOD CAR WRECK? - https://www.youtube.com/watch?v=5oO226PgSkg KULTULZ - HAS MOVED ON TO THE HAPPY PROVING GROUNDS |
04-24-2020, 05:53 PM | #3 |
Don’t know the kit, adapter and hardware worked for the calipers, rotors were wrong, bearings were wrong.
04-24-2020, 05:59 PM | #4 |
As Kultulz asked, we need more details - where'd you get it from, any info like did they have a part number or description of the kit, are you using the original Midland-Ross brake booster or something else, etc.? Pictures would be MOST helpful. Inquiring minds want to know...
Alan H. Tast AIA, LEED AP BD+C Technical Director/Past President-Editor-Publications Director, Vintage Thunderbird Club Int'l. (VTCI) http://www.vintagethunderbirdclub.net Author, "Thunderbird 1955-1966" & "Thunderbird 50 Years" 35+ year member, Crown Victoria Ass'n. |
04-24-2020, 06:10 PM | #5 |
If it's that wrong, doesn't fit and has no useful information about it...
maybe you should return it for a refund, or just cancel payment. . Last edited by dmsfrr; 04-24-2020 at 07:12 PM. |
04-24-2020, 07:03 PM | #6 |
You have to be careful on some of these kit sellers as they have no clue. Throw GM parts in a box and ship it.
04-25-2020, 07:07 AM | #7 | |
What modern style MCs will work with the original booster?
04-25-2020, 07:29 AM | #8 |
Well, that's the problem. What booster style did they include with the kit? A FORD MC might not mount to it. If you choose a FORD MC, you may have to use a different booster.
Can you show photos?
04-25-2020, 07:38 AM | #9 | |
My booster is good. Was curious if a Mustang, LTD MC would bolt to the stock booster.
04-25-2020, 08:48 AM | #10 |
OK, you are using the OEM booster? That narrows it down. I need to see how close the present MC is to the left side cross brace.
04-25-2020, 10:18 AM | #11 |
Here are some pics. Original booster with 68 Mustang (took it out of my car to test) MC. Other pics are the booster and MC that came in the box.
04-25-2020, 10:30 AM | #12 | |
Does the cross-brace clear the dual MC?
04-25-2020, 10:36 AM | #13 |
Nope, darn cross brace is hitting lid.
04-25-2020, 03:42 PM | #14 |
Two choices, cut a relief in the reinf (as little as possible) to allow the cap to be moved back and removed or find a shorter booster.
04-25-2020, 03:44 PM | #15 |
Yeah I’m trying to find a shorter booster
04-25-2020, 03:53 PM | #16 |
The booster you are showing is a 1968 MUST? How deep was the booster that came on the car?
04-25-2020, 04:06 PM | #17 |
No that’s the factory tbird booster
04-25-2020, 04:34 PM | #18 |
What's wrong with the original booster? Are you adding rear disc brakes? Kultulz is right the kit master cyl is GM usually for 4 wheel disc brakes. The Mustang master cyl you show is for drums (rear) disc on the front. The larger rear section on the Mustang unit is for the front brakes, smaller is for the rear drums. What's wrong with using the original booster and the Mustang MC you have?
04-25-2020, 05:36 PM | #19 |
Ok so I think there’s some confusion going on here, most likely due to my description of the issue. We were just fitting up that MC from the Mustang to see if it would work. It wasn’t already mounted on the car. Original booster works fine.
04-25-2020, 09:58 PM | #20 |
Can you give me the depth of the original booster?
04-25-2020, 10:12 PM | #21 | |
Have you tried looking in the 1963 Modified/Custom section of Vintage Thunderbird Club International's Forum? https://www.vintagethunderbirdclub.n...forum.php?f=23 Link below are to articles found by searching for disc brake conversion master cylinder booster https://www.vintagethunderbirdclub.n...linder+booster
04-25-2020, 11:16 PM | #22 |
THANX Allan ...
On this thread - https://www.vintagethunderbirdclub.n...hp?f=23&t=8899 - The first post has a REFERRING URL which should help understand the scrubby disc conversion. The booster the poster finally used was an aftermarket 9" - 3 1/2" depth fitted to the mounting bracket. See if that helps any. It should give needed clearance on the MC.
- WANNA SEE A GOOD CAR WRECK? - https://www.youtube.com/watch?v=5oO226PgSkg KULTULZ - HAS MOVED ON TO THE HAPPY PROVING GROUNDS Last edited by KULTULZ; 04-25-2020 at 11:22 PM. |
04-27-2020, 09:05 AM | #23 |
Thanks everyone. Sorry, wasn’t able to get out and measure it yesterday. I’m thinking the bracket at the back is what is killing me for space. Need to research these links. You all are the best. More to come!
04-29-2020, 06:00 PM | #24 |
I started researching this swap for someone with a '62 Bird and may wind up with the car myself. Those crappy Corvette masters, I would not use one. I liked that Ford dual master that was early in the thread. All better if you can match up the back of it with the OG one.
The car I'm interested in has drum brakes, new master and booster. I would leave it as is and make sure everything in the drums was ok. I saw something on the brace replacement, someone used one from a '64-'66 Bird or maybe modified it as well. The brace is pretty essential to the structure of the car. If I can find a good link, I'll post it. |
04-29-2020, 06:05 PM | #25 | |
Still working on this. Been pretty frustrating. Followed one of the links supplied and set up the new booster with the old mount and the darn from brake line port is just slightly too close to the shock tower. Going to try a 68 Mustang MC with the booster and see if that fits. Might have to put a remote fill cap on to get rid of the tall lid and bail.
Question I have is, the booster is set up for a shallow MC, the Mustang MC is deep bore. How can I convert the booster to have a longer rod? Quote:
04-29-2020, 07:40 PM | #26 |
04-30-2020, 10:21 AM | #27 | |
This is likely the answer. Even a piece of steel the right diameter would work. It does help to have friends that work in machine shops. Just measure up the differences to come up with the plug length. There is another Ford master that puts the lines on the inside. Look up Dorman M97934, but it may have a 7/16-20 port on it, you'll need that fitting. Not a big deal since you'll have to fab a line at some point. |
Thread Tools | |
Display Modes | |
