03-03-2013, 11:57 AM | #61 |
Re: Yes, they are still out there!!!
A second for sending them to skip.
Brad Williamson |
03-03-2013, 12:51 PM | #62 |
email address/phone/address to contact him and what is cost, thanks Bruce
03-03-2013, 04:42 PM | #63 |
Same guy that did the coils Bruce
DON P |
03-03-2013, 05:15 PM | #64 |
-vt
03-03-2013, 05:42 PM | #65 |
If it would have been a snake it would have bit ya! i can't spell my way out of a paper bag! |
03-03-2013, 09:11 PM | #66 |
03-03-2013, 10:22 PM | #67 |
Thanks will contact, Bruce
03-05-2013, 06:50 PM | #68 |
Got the fuel pump and carburetor back from Ken in Ct., today, also received the flex hose, waiting on MAC's parts and pieces to start the re-assemble.
03-07-2013, 04:55 PM | #69 |
Good Day, got the spare tire lock in locking hub cap to move and release!
. 1. Removed spare tire, tire band and locking strap ( spare tire still has the whiskers on tire ) The old 17" tires are Lester Tire Co., now have 5 tires available. . 2. . Re-mounted the 17" green rim to see how it will look, got 5 of them to install after I get the car running. Lincoln Tire Co. . 3. Also, sent coil and water pumps to SKIP this morning. |
03-08-2013, 06:35 PM | #70 |
Mac's parts arrived today, removed lower hoses this evening, old hoses were as hard as a rock, then removed the motor mounts, when I had looked at them there were strings of material hanging down for the passenger side mount, ( like it was melting ) finally got both of them out. Now I opened package with new motor mounts, BUT something is not working out, first the hole is cross member is smaller than the lower bushing, looks to be 5/8" hole and the bossed part of lower bushing is 7/8", also the top side of cross member is recessed, the large washer is bigger than the recess, any info is appreciated!!!
1. Old motor mounts and one new one . . . |
03-08-2013, 07:26 PM | #71 |
The mounts you got from Macs are not correct for the 34. They are junk. They dont have the correct lower mount and the upper mount does not have the metal insert in it. Give Joblot a call and tell them what you need , they may have nos ones or Dennis Carpenter..
03-08-2013, 07:33 PM | #72 |
Thank you, I thought I would start by grinding of the lower shoulder bushing, cutting down the upper washer, nothing fits, I called Don P. to show him the photos, we even thought of opening the cross member hole to 7/8" but still does not help the recess in top of cross member, thanks for help, thought is was just me, Bruce
(Joblot, who or how do I reach him/them) I will look at Dennis Carpenter now. |
03-08-2013, 08:29 PM | #73 |
I like your restorer "BAND AID" the same kind that I use
03-09-2013, 07:59 AM | #74 |
Hope you mean my Duct Tape (Duck tape)
Found some new/old information on 34 motor mounts: https://www.fordbarn.com/forum/showth...4+motor+mounts Last edited by Bruce in southern OH; 03-09-2013 at 09:00 AM. Reason: Additional information |
03-11-2013, 05:16 PM | #75 |
Have started re-assembly of engine, motor mounts and lower radiator hoses. Waiting on coil for distributor and water pumps before any more parts placed on engine. Also, removed all the front end wiring today, very oil soaked and brittle, lots of areas on wire that were bare.
. Motor mounts . Sat intake on block . Removed a bucket full of old wiring . |
03-11-2013, 05:19 PM | #76 |
Ahhh! progress.
03-11-2013, 07:43 PM | #77 |
Bruce, that is going to look great, I like the wheels, man those motor mounts were beat...
03-25-2013, 05:50 PM | #78 |
Found a good set of chrome bumpers, waiting on pumps and coil for start up, swap meet in Winfield, WV this past weekend was great. Not many flathead parts, but did pick up a radiator cap for 33 BB truck.
03-27-2013, 06:29 AM | #79 |
This is cool, great find and I like what your doing with it.
Vintage Drag Meet MeltdownDrags - Byron IL. July 15-17 2016 www.meltdowndrags.com |
03-29-2013, 06:58 PM | #80 |
Got my water pumps back this evening and coil, will start installing them next week, and then re-assemble the top end, go for a start then. Tell me some information about the water pumps, old impellers as I remember had parts to them, spring etc., new re-built look like a one piece model A type impeller, what is the advantage?? On the water pump with temp sending unit, what is the small set screw used for? Also, are the pumps painted Ford green like the engine, these are charcoal color? Thanks for all the help, Bruce
. Does brass fitting need special dope/Teflon tape? . . Set screw or access screw? . Do you think the very bad corrosion on water neck will cause problem, no ring/ridge for hose to slip over, leak? . |
Thread Tools | |
Display Modes | |
