02-27-2020, 06:43 PM | #61 |
Re: 1933 inner fender question?
DavidJ, these were before I bent the left gusset down, phone charging, will load some latest pix later tonight.
THANK YOU |
02-27-2020, 07:44 PM | #62 |
02-27-2020, 07:46 PM | #63 |
The left gusset was a little higher than the right, was able to bend it to match, looks better. Needs a little more tweeking, thanks again for your help.
02-28-2020, 08:38 AM | #64 |
How are the body beads lining up ?
Pic one in post 23 shows the RH looking pretty good . Pic one in post 40 shows the LH being quite high . Is it still like that ? Has this car had lower cowl sections replaced ? Looks like a little more back on the left rad rod may be needed also . Last edited by David J; 02-28-2020 at 08:43 AM. |
02-28-2020, 10:50 AM | #65 |
02-28-2020, 10:54 AM | #66 |
02-28-2020, 11:40 AM | #67 |
Looks to be getting pretty close .
Time to try the inner skirts . Give me a call Doug when you get a chance . |
02-29-2020, 09:04 AM | #68 |
Doug can give a better account of what he has done as he is doing it .
I am just a coach . That said what we have been working with is the radiator support rods and radiator mounting pads . As you can see there is much to be gained by messing with these adjustments . |
02-29-2020, 08:13 PM | #69 |
02-29-2020, 08:16 PM | #70 |
Here are a few more after today's work, had problems with my radiator/grill brackets. Looks better than it ever has,
BIG THANKS AGAIN TO DAVIDJ Quite the coach he is. My fingers are sore after taking this apart many times, |
02-29-2020, 08:36 PM | #71 |
02-29-2020, 08:42 PM | #72 |
Went ahead and installed lower radiator hoses before the inner fenders. This project requires LOTS of patience/adjustments. I am very pleased with the results.
02-29-2020, 09:58 PM | #73 |
03-01-2020, 12:07 AM | #74 |
Thanks for posting the results. It's wonderful to see a conclusion to a process and the step by step tutorial to achieve the goal.
03-01-2020, 07:49 AM | #75 |
Tomcarman, thanks for your comments, still have a way to go, fenders, welting. Weather here is warming, that's a big help.
03-03-2020, 11:28 AM | #76 |
I hopefully can get my 34 that close! Good job!
Thread Tools | |
Display Modes | |
