09-08-2023, 06:00 PM | #61 |
Re: Tachometer for my model A
Love having a tach .
I’m used to working on performance V8’s from the 60’s ,70’s so after seeing the crank and rods in the A I want to keep those revs down! |
09-08-2023, 06:52 PM | #62 |
I have a tach in my 30 coupe without overdrive but with a burtz.very interesting to see the rpm of shift points and at cruising speed. Because of the stroke the piston speed of a model A is very impressive, comparable to sbc.
09-08-2023, 07:34 PM | #63 |
That's me too. I don't even intend to try. what did Henry say about systems that are old are not necessarily redundant?
Remind me please.
I know many things, But I don't know everything, Sometimes I forget things. And there are times when I have a long memory. Last edited by woofa.express; 09-08-2023 at 08:21 PM. |
09-08-2023, 08:51 PM | #64 |
210 ci. 168 hp. 6400 rpm.
Drove all over LA for 3 days in 104 degree heat and got 18 mpg. Won class in national hill climb while there also. Modified can also be very steetable. |
09-09-2023, 01:20 PM | #65 |
Pete, I believe that small tach you featured in post #13 is similar to the 0-3000RPM tach I bought last year on eBay. The maker is Buzztach, not Westach and the one I have is Buzztach Model P3A 6 Volt Model A tachometer designed to be used with Pertronix’s ignition system. I had a late forty's vintage Sun Tach that I replaced with this Buzztach.........What a great little tach!!!!!
AL in NY |
09-09-2023, 03:48 PM | #66 | |
06-04-2024, 10:04 AM | #67 |
Yes, TomEndy, I installed a TinyTach. I used one of the bolts in the dashboard to secure the LCD screen. I threaded the wire thru some loom and exited the Terminal Box to the ignition coil cable. I ground the device well (check with multimeter first) to the coil bracket-firewall screw.
The whole process required 25 mins of my time. It worked quite well and continues to function without issues. Diastole in the Smoky Mountains
A little learning is a dangerous thing. Drink deep, or taste not the Pierian Spring; There shallow draughts intoxicate the brain, and drinking largely sobers us again. |
Thread Tools | |
Display Modes | |
