#41 |
forgot the photos
#42 |
forgot the photos
#43 | |
![]() Quote:
Now is the intake nipple attached to the cover pointing/drawing towards the inside of the filter element or the outside? Were there any ID markings on the PCV valve itself? How was the hose(s), dry? |
#44 |
It looks like the nipple draws air from around the outside of the filter. Hose did not look wet.. I didn't notice any markings on pcv , but will look closer tomorrow Fred
#45 | |
![]() Quote:
#46 |
#47 |
Can you show a photo of just the canister (6869) inverted with the filter (6A631) installed and the relation of the nipple to the actual filter placement?
THANX! Last edited by KULTULZ; 12-01-2021 at 01:14 PM. |
#48 |
will do
#49 | |
![]() Quote:
There had to be a period TSB('s) on the system. ![]() ![]() ![]() ![]() |
#50 |
Kultulz.. here are a couple photos you asked for .. It looks like the suction would be partially into the filter material .. On the valve it says AC I think the number is 534640
#51 | |
![]() Quote:
The nipple has to be located within the filter media when the canister is installed on the tube. Otherwise, the draft will be drawing directly from the crankcase with no oil separator. Does that make sense? AC is most likely factory assembly (if the system is factory supplied). |
#52 |
Yes , but other pcv's arn't filterd to my knowledge.... this one looks like it would be partialy into the filter
#53 | |
![]() Quote:
Somehow, the filter media will have to be stretched over the nipple opening without distorting it so that it will still seat on the tube filter flange correctly. Otherwise it will suck fumes from the crankcase, especially with this particular design (as it has most likely been doing). FORD stopped using this design on 57 CAR and 59 TRUCK and went to the more familiar road draft tube. |
#54 |
HMMMMM... I'll have to think about this one.... Fred
#55 |
Could you maybe rotate the wide portion of the filter around from the 2 o'clock position to the 7 o'clock position to cover the nipple? Or is it permanently attached in its current position?
Often wrong but never in doubt. |
#56 |
#57 |
Dobie.. it does rotate but the best I can get is to draw pretty much right on the edge of the filter material . I'm thinking about pushing some extra of that filter material in the pickup tube before the pcv valve . I dont think it would suck any pieces up.. What do you guys think ? thanks Fred
#58 |
But you understand what I am tying to describe?
Below is an ILL of a late 5.0L EFI PCV install that has a separator under the actual valve. It is a wire mesh type filter - Without that filter/separator, the system will draw fumes, moisture and oil into the combustion chamber(s).
- WANNA SEE A GOOD CAR WRECK? - https://www.youtube.com/watch?v=5oO226PgSkg KULTULZ - HAS MOVED ON TO THE HAPPY PROVING GROUNDS |
#59 | |
![]() Quote:
#60 |
Yes I understand the concept, just trying to make something that will work in my situation .. I will leave the filter on it for a seperator and possibly add more of the same type material that will cover the complete end of suction tube. It would be same filter media not steel wool or something that would deteriate thanks Fred
Thread Tools | |
Display Modes | |
