08-16-2018, 03:59 AM | #41 |
Re: 50 flatty idles well revs okay, but will not drive down the road.
Not sure if it has been mentioned, but the filter looks very dirty. Have you tried replacing it?
08-16-2018, 06:41 AM | #42 |
I agree with "Mart" on this. It looks to me that either the filter may be dirty or the fuel may be contaminated. Another thing I would look at is the rubber line from the carburetor to the distributor. I have always seen hard lines here and would make sure the proper fittings have been used so there are no leaks.
08-16-2018, 08:25 AM | #43 |
Count me in on the fuel filter and the color of the gas. Looks pretty bad to me and an easy fix. Also, could explain your symptoms!!!
08-16-2018, 10:41 AM | #44 |
Try running it without the air filter. Some aftermarket air filters are very restrictive and make for a bad running flathead. KN makes a good air filter. Good luck!
08-16-2018, 10:58 AM | #45 |
Here's my solution to those restrictive little air filters everybody seems to have. I have since changed to something better.
08-16-2018, 10:18 PM | #46 |
. The charging system was weak and not putting out enough juice. |
08-17-2018, 09:49 PM | #47 |
I will get at it tomorrow morning with all the great advice. thanks. i will let you know what I find out.
08-18-2018, 08:18 PM | #48 |
how would i determine if the generator is charging correctly? would it be similar to checking an alternator with a voltmeter on the battery? could the swap from 12v pos ground to neg ground cause an issue? when I was a teen the generator worked if I drove it enough but from time to time would need a charge. this is just a generator issue I believe.
a few months ago I drove it and it would go about a 1/4 mile and die. now it will not go a few hundred feet before it dies. i will install the new napa coil tomorrow and see if that does anything. fuel is good, filter was ugly and yellow so i put a new one on anyway that looks better. |
08-19-2018, 12:02 AM | #49 |
You have a voltage Regulator, early fords used a cutout. Cutouts are off or on only charge.
I'm assuming you have a 12 volt regulator and gen to this point. Yes check volts to the battery above idle. Regulators need to be polarized, may or may not be an issue on your switch. Hard to say.. |
08-19-2018, 12:13 AM | #50 | |
You fix this? Look at coil, ignition and fuel. Most ignition issues are fuel. and vice versa. I'll bet, coil/condenser/ignition here. classic hot coil symptoms. but... Last edited by Tinker; 08-19-2018 at 12:44 AM. |
08-19-2018, 11:47 AM | #51 |
I run a round coil on our 38dlx. coupe, got one at NAPA, the car started and idled fine, but wouldn't pull itself, they had given me one with the resister built in, got one without resister ran fine....just a thought
08-19-2018, 08:36 PM | #52 |
new napa coil, bypassed the fuel filter and regulator, checked timing, set at 17 btdc, 2 plug wires were not firing, got this fixed. still the same. checked the generator, 12.41 volts off, running at 12.31 volts. doesn't seem to be charging which could be the issue. I will check the condensor as well. i think I have multiple items to work on. thanks for the advice and i will keep you posted.
08-19-2018, 08:46 PM | #53 | |
08-19-2018, 09:12 PM | #54 |
Agreed doesn't make sense.
Believe initial is around 4 degrees before tdc. Around 22-8-sh all in for "standard" performance. To add another wrench stuck valves could give symptoms you are describing. Some MMO down the throat and some in the gas will loosing them up, easy process and practice. Can't hurt. ....But your timing is not right, if that's really how it is. Change one thing at a time to fine tune it. Last edited by Tinker; 08-19-2018 at 09:24 PM. |
08-20-2018, 09:55 PM | #55 |
JSeery, Tinker, ill check the timing again. what rpm for 2-4 degrees? what does 22-8-sh mean? great idea of MMO. a compression test would diagnose a stuck valve, correct.
I am also looking at the generator not genning. looking at a Powermaster 82021 alternator. anyone have any experience with this unit? its 350 bucks so not cheap. thanks for the help. |
08-20-2018, 10:04 PM | #56 |
Initial timing is checked at idle (normally somewhere around 500 rpm or less). Timing should be all in around 2000 - 2500 rpm and be around 22 degrees or less. How are you checking the timing, a dial back timing light? How are you checking the rpm? Which spark plug are you using as #1?
08-20-2018, 10:25 PM | #57 |
#1 plug wire, closest to the distributor, using a bosch timing light that can show the rpm and advance-retard the degrees. checking timing with the vac advance plugged. i think i need to rotate the distributor one gear tooth. could be part of my problem. thanks man.
08-21-2018, 12:56 AM | #58 |
If itīs the original loadamatic distributor and you plug the vaccum you should in theory get a static timing....
08-21-2018, 07:05 AM | #59 | |
no "in theory" about it. I drive a 36 ford stock car with an 8ba in it and when the owner's electronic mallory fried I took his stock 8ba unit and dropped it in minus vacuum. set the timing to 16 degrees and she runs and starts like a champ. figured I would get some starter kick back but at 12v no issues. |
08-21-2018, 07:32 AM | #60 |
If you are going to drive it with the vacuum hooked up, you need to check it with the vacuum hooked it. It in not like a later distributer with both mechanical and vacuum advance (assuming original loadamatic), it only has vacuum advance and will not operate as designed without the vacuum connected.
Thread Tools | |
Display Modes | |
