Old 11-27-2023, 12:25 PM   #1
Jim Brierley
Default Re: Claim of 25% HP bump true?
Originally Posted by 1928 Sport Coupe View Post
I would like to install a High Compression head in either 5.5:1 or 6:1 such as Snyders, a "B" cam, a "B" carb, and a bored out "A" intake. If I were to use new poured Babbitt mains and rods would that be sufficient for the improvements I want to do? Which head would be the better choice, the 5.5:1 or 6:1? I have been told any HC head could destroy the center main bearing if you drive it at all aggressively. I would just like to be able to keep up with traffic when needed.
As far as I know this is the original 35K miles engine in the car (1930 Town Sedan) and I would like to keep it in the car. This way I could always return it to stock.
Thanks
Higher compression and other things that make more power CAN be harder on bearings, BUT don't if you ease back on the ignition timing a bit, which does 2 things. 1) it prevents detonation and 2) is needed because the fuel will be burning faster so is more apt to knock (detonate) Also, driving down the road takes exactly as much power with or without more power, so most driving will not affect the babbitt or anything else.
Jim Brierley is offline   Reply With Quote
Old 11-27-2023, 12:15 PM   #2
Jim Brierley
Originally Posted by brito36 View Post
With all the conversations on increased compression, larger carburetors, and intake manifolds, I would make sure that my lower end could handle all these improvements.
Always a good idea, I have always run Model B engines, and they are strong, bigger bearings and better oiling system, but A engines are very strong and reliable too.
Old 01-17-2024, 11:13 PM   #3
Charlie Stephens
I was just going to post to watch out for the top end. Be sure there is adequate clearance between the head and the piston. The original and many reproductions had a recess in the head above the piston. Many high compression heads lack this recess. If the top of your block has been machined a couple of times you could have a problem when the piston pops up above the block..
Charlie Stephens
Old 01-18-2024, 08:48 PM   #4
Synchro909
Synchro909's Avatar
Easy fix. Wear a diaper.
I sometimes wonder what happened to the people who asked me for directions.
Even at my age, I still like to look at a young, attractive woman but I can't really remember why.
Old 11-27-2023, 08:48 AM   #5
AzBob
Old wives tale about a 5.5:1 or 6:1 high compression head taking out the bearings. I run a 6:1 Snyders head and get better mileage more power and a cooler running engine.
AzBob is offline   Reply With Quote
Old 11-27-2023, 07:12 PM   #6
31a
he parts suppliers have a small a adapter kit that allows the B carb to align properly.
31a is offline   Reply With Quote
Old 11-29-2023, 09:51 AM   #7
Fullraceflathead
Fullraceflathead's Avatar
If you think of the engine as half of a 400 cubic " V8 it's easy to see how under carburetor the engine actually is!
"If I asked people what they wanted they would have said faster horses."
-Henry Ford
"Primitive technology is not a design flaw"
1928 Ford Model A Roadster Pickup
1930 Gordon Smith Air Compressor
1941 Willy's Pickup
1960 Thunderbird-For Sale
1964 Buick Riviera 2x4 425
1965 Pontiac GTO, 455 Super Duty
2004 Dodge Ram SRT-10, V-10 Viper
1977 Charger Jet Boat,460 Ford,Jacuzzi Jet
Front Engine Nostalgia Dragster,Supercharged 296 "Fullrace Flathead" Ford
Engine Build up on DVD ask
Fullraceflathead is offline   Reply With Quote
Old 11-29-2023, 10:00 AM   #8
47topless
47topless's Avatar
Great point! Maybe I should look for a four banger blower. Now we're talkin' SLEEPER
47topless is offline   Reply With Quote
Old 11-29-2023, 01:35 PM   #9
Terry Burtz, Calif
Check this out https://www.facebook.com/groups/1123...1121704006913/
Blowers are available from Aaron Loveless https://frenzelsuperchargers.com/pro...VUJygiHVLnUsd8
Terry Burtz, Calif is offline   Reply With Quote
Old 11-29-2023, 11:12 AM   #10
nkaminar
nkaminar's Avatar
Dyno tests are here: https://www.modelaparts.net/dynoshee...ynosheets.html
Old 12-01-2023, 09:15 AM   #11
old31
Talking about HP.
Does anyone know the difference in the Burtz 6.5 HP vs Snyder's 6.1HP?
Old 12-01-2023, 11:09 AM   #12
nkaminar
nkaminar's Avatar
From my experience there is a little boost going from the Snyder's 5.5 to the Burtz 6.5. In my opinion, the Snyder's 6.1 head has a better combustion chamber design than the Snyder's 5.5 or the Burtz 6.5 so it might be better than either of those, but I don't have any data to back that up.
Old 12-01-2023, 12:44 PM   #13
Big hammer
Synder’s 6.1 head is 6.0 compression ( in their catalog 6:1) and their 5.5:1 if anyone cares
get a bigger hammer tap done
Old 12-01-2023, 04:53 PM   #14
Cape Codder
Cape Codder's Avatar
years ago I bought a 5.5 head from Snyder's only to find it was approx. 1/8"-3/16" too short in front and rear. I'm just wondering if this still exists? Of course they refunded my money and paid for shipping both ways!
I don't care if the "A" Starts BUT sure WANT IT TO STOP!
Cape Codder is offline   Reply With Quote
Old 01-16-2024, 09:13 PM   #15
Ruth
Yes
Ruth
Thread Tools
Display Modes
