Old 12-09-2014, 02:20 PM   #1
31 Model A
31 Model A's Avatar
Location: Here I am in front of Todd's Grocery in 1931 selling Grit newspapers
Default Official names are?????
Need to order these peddle arm surrounds????? What officially are they called? Or the pad underneath.
Cheers..............
"Bullshit and Brilliance Comes with Age and Experience"
"Hey Lady, ya wanna buy a Grit?"
"If you don't learn to laugh at trouble, you won't have anything to laugh at when you're old" Will Rogers
31 Model A is offline   Reply With Quote
Old 12-09-2014, 02:26 PM   #2
Mitch//pa
Default Re: Official names are?????
i reccomend buying the powder coated ones from snyders... brattons are bare metal and need to be painted... separately youll need the felt pad and screw kit..
"""floor board pedal plates"""
Old 12-09-2014, 02:27 PM   #3
31 Model A
31 Model A's Avatar
Originally Posted by Mitch//pa View Post
i reccomend buying the powder caoted ones from snyders... brattons are bare metal and need to be painted... separately youll need the felt pad and screw kit..
Thanks Boss..................
Old 12-09-2014, 02:52 PM   #4
31 Model A
31 Model A's Avatar
On-order. I think with this replacement, I've closed up as much as I can any open space between the cab and the engine, leaving gas fumes from mingling with the sweet smell of perfume from any of my lady friends riding along with me.
Old 12-09-2014, 04:38 PM   #5
rocket1
I would make your own pads from brown carpet underlayment (padding) It is thicker and you can trim it closer to the pedals and column to stop those air leaks,the part they sell leaves to much room around the pedal arms.
rocket1 is offline   Reply With Quote
Old 12-11-2014, 10:51 PM   #6
redmodelt
redmodelt's Avatar
Not only that but why do they have to do the cut right at the joints for the two pieces? I don't care if Ford did it that way it's dumb! Leaves more gaps.
Old 12-13-2014, 12:20 PM   #7
31 Model A
31 Model A's Avatar
Took your advice and acquired a thin piece of indoor/outdoor carpet in case the felt pad came up short, it didn't, just took some time to get the placement right. I'll keep it on hand anyway in case the opening starts wearing away. Thanks..............
Old 12-13-2014, 12:31 PM   #8
Y-Blockhead
Y-Blockhead's Avatar
The stuff you buy lasts about a minute until the clutch pedal enlarges the hole again...
